4Runner Sitting for Years and Won't Start
#757311
10/12/06 07:47 PM
I found a 1990 4Runner that has been sitting for 3-4 years and is claimed not to start. What should I look at prior to purchasing a vehicle that has sat for that long? I'm not very familiar with the V6, but I know the rest of it quite well as I had a 1989 pickup with the 22RE. Would it be safe to try to turn the motor over or should I do something first?
Thanks
Re: 4Runner Sitting for Years and Won't Start
[Re: bikedoctor]
#757312
10/12/06 11:36 PM
Probably at a minimum pull the spark plugs and give each cylinder a squirt of oil. Then try cranking the engine over w/o the plugs in to see if it'll turn over and if the oil pressure will come up.
[Re: 4Crawler]
#757313
10/13/06 12:05 AM
Drain all the fluids, including the gas. Shoot oil down into the cylinders, as mentioned above. You might want to try turning it over for a while (no plugs) until you get an indication of oil pressure.
After 3 years, the fuel may be in bad shape...
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5932 MB (Peak: 0.6464 MB) Data Comp: Off Server Time: 2026-06-20 09:42:33 UTCValid HTML 5 and Valid CSS
