a/t light and speedo problem
#757599
10/13/06 08:17 PM
Ok a while back i posted about my crank sensor giving out and now my car runs great but i'm having a new problem after i replaced the crank sensor i noticed my a/t light blinking and my speedo is not working before my crank sensor gave out i had no problems.
this pass spring i replaced my tranny with a used tranny that had less miles then my orignal. oh and this is for a 95 montero ls 3.0
thanks lee
Re: a/t light and speedo problem
[Re: darkroom1428]
#757600
10/18/06 03:40 AM
Wish I had an answer to your issue. My 89 has the A/T temp light on all the time after the rains in Houston this week. Any ideas? Good luck on yours.'\ KD
3 rides, 1 smashed, 2 with bad motors, going to rebuild it he says, going to try! Hate to say it. Never have time and money together. The raiders all of them are available. Parts or whatever you want. Bought a Chevy Colorado 2005 Crew Cab Z71 4x4
[Re: darkroom1428]
#757601
10/18/06 04:01 AM
Probably means your electronic speed sensor on the transfer case has gone bad (or the wiring in between has been clipped/worn). My first thought would be to replace it and see what happens from there.
[Re: hd77303]
#757602
10/18/06 05:53 AM
Wish I had an answer to your issue. My 89 has the A/T temp light on all the time after the rains in Houston this week. Any ideas? I suspect the sensor's shorting out because the seal's no longer sealing properly.
PHP: 7.4.33 Page Time: 3.263s Queries: 15 (0.004s) Memory: 0.6008 MB (Peak: 0.6573 MB) Data Comp: Off Server Time: 2026-06-07 06:19:34 UTCValid HTML 5 and Valid CSS
