Re: 1993 Montero V6 3.0 No Spark [Re: sparkem] #757613 10/18/06 01:47 AM
Bijol Offline OP
I'm almost certain that the ECU is dying. I got a couple of codes off it while it was working, and then the engine quit. I'm getting a constant 12V off the ECU test terminal now.
Has anyone gotten a rebuilt ECU off eBay? They run about $189, which is considerably cheaper than the $250 advertised price from http://www.autocomputersupply.com/.
Re: 1993 Montero V6 3.0 No Spark [Re: Bijol] #757614 10/18/06 07:30 AM
Bijol Offline OP
Well, after much dismay, I've found what is causing the ECU malfunction. I took apart the unit, and after fiddling around with it, I saw a black crud on the wiring harness connectors.
ANTS!!
Check out the upper left hand solders:
Closeup of same picture:
ECU Mounting Plate with circuit board removed:
So, I guess that the lesson learned here is be sure to spray your truck for ants and bugs. A $3 can of insecticide could've saved about $300 in repairs...
My ECU is off to the repair dudes via Fedex 'cuz a couple of ants nested inside it...I hope someone gets a good laugh outta this one, I know I did... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 1993 Montero V6 3.0 No Spark [Re: Bijol] #757615 10/18/06 11:34 AM
Y
yankneck696 Offline
1989 ECU's only directly interchange with 89 Raiders & monteros as the Hollander Interchange program tells me here at work.
Ed
Yankneck = Yankee ingenuity with Redneck stupidity.
"How can I break it better?"
89 Raider 3.0 w/ 31's for now
Re: 1993 Montero V6 3.0 No Spark [Re: yankneck696] #757616 10/18/06 11:47 AM
FrankR Offline
That's correct - the '90s and '91s used a different distributor and ECU..... '89 was a 1-year run for distributor and ECU.
Frank
Re: 1993 Montero V6 3.0 No Spark [Re: EspressoBob] #757617 10/27/06 03:46 AM
Bijol Offline OP
**UPDATE**
Well, I got myself a rebuilt ECU from a seller on eBay, and even without a core charge! I got a GREAT deal and for a little more I got "extended warranty" on it. The seller offered 30 days and a non-DOA, and for 10% of the price he offered 1 year to return the unit if it dies on me.
I plugged the ECU in, and it's been working perfectly. I'll give it a final run before I spray it for bugs!
Click HERE for the seller's eBay Store.
Thanks to everyone that helped me diagnose my problem!! <img src="/forums/images/graemlins/smile.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6121 MB (Peak: 0.6771 MB) Data Comp: Off Server Time: 2026-06-07 03:07:10 UTC
