American Bolt in the Bell Housing? 1988 Trooper II #757631 10/13/06 11:19 PM
AndyR Offline OP
Hi, I recently rebuilt my 1988 Trooper II engine, and I am now hooking the transmission back to the engine. There is one bolt hole that doesn't seem to want to thread in. This bolt is the ONLY one that threads into the transmission from the engine side, all others go directly into the engine block. I am wondering, could this be some strange american thread? I tried going to the junkyard and threading one of my bolts into a similar transmission there, and it did the same thing, it just doesnt feel right. Any help would be very appreciated.
1988 Trooper II in the works.
Re: American Bolt in the Bell Housing? 1988 Trooper II [Re: AndyR] #757632 10/13/06 11:47 PM
CPOM Offline
I know some engines use pilot dowels and there is often a hole but no threads. Did you take hardware out of the hole or did you just notice it was missing?
disregard that you are talking 2.6 motor right? I thought GM.
CHRIS
98 Amigo, 92 Pup
Re: American Bolt in the Bell Housing? 1988 Trooper II [Re: AndyR] #757633 10/13/06 11:59 PM
litnin Offline
If it's the one I think you are talking about,
it's a coarse thread bolt, unlike all the others, which are
fine thread.
If I'm not mistaken, it's on of the starter bolts.
1995 Trooper LS auto 3.2 DOHC /w SOHC intake
1989 Trooper 2.6 auto
1989 I-Mark RS DOHC 1.6
1991 Stylus XS DOHC 1.8
Re: American Bolt in the Bell Housing? 1988 Trooper II [Re: AndyR] #757634 10/14/06 01:50 AM
JLEMOND Offline
IF IT IS THE LOWER BOLT ON THE STARTER IT IS A 10 MM BY 1.5 MM THREAD PITCH, THE SAME AS THE STUD ON THE TOP OF THE STARTER WHERE IT THREADS INTO THE TRANNY CASE ONLY TWO ON THE ENG OR TRANS ATTACHMENT BOLTS THAT ARE 1.5, JERRY
Re: American Bolt in the Bell Housing? 1988 Trooper II [Re: JLEMOND] #757635 10/14/06 05:30 AM
AndyR Offline OP
Awesome guys, thanks, I was just out there trying to fix it and I found that bolt. A little bit of a small distinction if you ask me, but I guess next time i'll sort the bolts out better. Thanks again, that really helped.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6037 MB (Peak: 0.6682 MB) Data Comp: Off Server Time: 2026-06-19 12:12:05 UTC
