rear mount for sas #757957 10/15/06 07:50 PM
roadayo1 Offline OP
I was wondering if anyone who has sasd a rodeo has a good picture of how the rear of the spring is mounted in a front shackle set up.
Re: rear mount for sas [Re: roadayo1] #757958 10/16/06 01:47 PM
RobG Offline
is your question about placement or fabrication? each setup is different, so no one will be able to tell you exactly where to place your hangers. as far as fabrication, a simple "bucket" is all thats needed. You can fabricate your own out of plate or square tubing, which is pretty simple, or many 4x4 vendors will sell you weld on versions premade if you'd rather not make your own. 2.5" wide leaf springs are pretty much the standard, so these are all over the place in jeep, toyota, chevy, etc vendors. here's an example from allpro:
http://www.allprooffroad.com/images/stories/suspension/rear_hanger_l.jpg
-Rob
Re: rear mount for sas [Re: RobG] #757959 10/16/06 02:29 PM
A
anubis Offline
polyperformace.com and bluetorchfab have nice ones as well at reasonable prices.
2002 Honda Passport. 3 inch Indy4x lift with 912 OME's. 265 75 BFG m/t's with a 3 inch body lift, safari rack, tube sliders, tube rear bumper, on-board air
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5916 MB (Peak: 0.6456 MB) Data Comp: Off Server Time: 2026-06-05 17:56:30 UTC
