Electrical issue #758195 10/16/06 03:38 PM
I
igneous Offline OP
Have a '01 Rodeo and the dr. side rear brake light don't work at times...usually when I have the lights on. Also, the rear wiper only works intermittantly. Could these be related and has anyone else had same problems and fixed it?
Thanks <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Electrical issue [Re: igneous] #758196 10/17/06 11:57 AM
TrailMystic Offline
Hopefully it's not the wiring harness like my '01. Some 2nd Gen Rodeos have issues with harness, although it is uncommon. I assumed you checked and cleaned all the connections. It's easy to pop off the rear plastic door panel. Just reseal the plastic liner well when your done checking things.
Pete
'01 Rodeo Sport, 5 Speed Softie, Indy 4X rocker bars, OME 912's, Rancho 9000X's, Superwinch hubs, custom tube bumper with Warn 9000i , Flowmaster 50, TeraLow t-case gears, ARB front & rear lockers, TrXus MT's, Sway bar disconnects
Re: Electrical issue [Re: TrailMystic] #758197 11/10/06 08:34 PM
Hi,
having the same issue on my '99 Amigo HT V6 4WD. Also seemed like my alarm wasn't responding sometimes but I thought that was just the remote battery. Actually mine has gotten worse as it started out with your symptoms and now has progressed to where my dash lights and rear lights don't work (brake lights and some of the dash indicators like gear still work).
I found the 15A fuse for "Tail/illumi. Light" busted, so I replaced. Once I did this all the lights worked again and so did the rear wiper - for about a minute. I tried it with the radio off after a replaced with a new fuse again, same result, it works for a minute or less and then -pop. I installed my own stereo, speakers, and sub a while ago and all has been working for years and then suddenly this. Even without replacing the fuse all the stereo stuff works - just not the tail lights, rear wiper, and dash instrument lighting.
Does anybody have any suggestions before I take it in to have it looked at?
Re: Electrical issue #758198 11/11/06 05:11 AM
Jim_Paget Offline
Check your trailer wiring, if you any. A short there is a common cause of these symptoms.
Jim Paget
88 YJ with a few changes
www.rrr4x4.com
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5940 MB (Peak: 0.6540 MB) Data Comp: Off Server Time: 2026-06-24 05:00:20 UTC
