Brake drum removal bolt size? #758559 10/17/06 05:08 AM
btn Offline OP
Anyone know the size and pitch of the bolt holes in the rear drums that you can use to push the drum off the axle on the 89-95 trucks?
thanks!!
1989 reg cab pickup, 22re, 31s, 4.56s, rear ARB, rear OME springs, RS9000s, otherwise stock.
Re: Brake drum removal bolt size? [Re: btn] #758560 10/17/06 05:30 AM
Should be M8x1.25
Re: Brake drum removal bolt size? #758561 10/17/06 05:57 AM
4Crawler Offline
Yep, that is the size, about 50mm long works well. Use lots of anti-sieze on the threads and alternate between tightening the two bolts.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5900 MB (Peak: 0.6430 MB) Data Comp: Off Server Time: 2026-06-08 18:50:13 UTC
