Tire size for a GenII #759124 10/18/06 09:41 PM
Robb Offline OP
Hey guys, first post, I just bought a 92 Montero 4x4 base model. I will crank the torsion bars up to level it out, and do a 1 inch bodylift on it - what tire can I fit on there with the stock 15 inch wheels? Will I be able to fit a 32 with out rubbing? Thanks!
-Robb
1992 Montero (pics)
www.HondaForeman.com
Re: Tire size for a GenII [Re: Robb] #759125 10/19/06 03:41 AM
DavidG Offline
Hello Robb and welcome to the 'Wire. You should be able to fit a 32x11.50 tire on factory 15x7's without modification. I know many of the folks with mid-90's SR's have run 33x12.50's on a stock (or only slightly cranked) rig. I cranked the torsion bars only an inch or so and I run 33x12.50's. I'm not sure about the rim width or offset on a base 1992, so if they're only 6" wide you may want to consider a tire narrower than 11.50. There are a variety of opinions on the best tire width vs. rim width combination. Personally, I think a 15x7 and 32x11.50 would be fine. My 33's are on 15x8's. I'm sure others will post and give you their opinion.
1997 Montero SR
<a href="www.georgiaoverland.com" target="_blank">www.georgiaoverland.com</a>
Re: Tire size for a GenII [Re: DavidG] #759126 10/19/06 03:47 AM
Robb Offline OP
Thanks <img src="/forums/images/graemlins/kewl.gif" alt="" />. The tires stock on here are tiny 235/70/15 = 28inch tire, looking at this truck and doing a few half a$$ measurements, it looks like I would be lucky to fit a 31 inch tire on there. <img src="/forums/images/graemlins/confused.gif" alt="" />
Here is a pic of the truck in question, I want to use the wheels on it, that I assume are stock
-Robb
1992 Montero (pics)
Re: Tire size for a GenII [Re: Robb] #759127 10/19/06 04:00 AM
CapnCrunch Offline
Yes, tiny tires but nice looking truck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Welcome to the wire!
?_________
|_|_|\____\___
()_)()_)-----)_)
Stay the Trail!
Re: Tire size for a GenII [Re: CapnCrunch] #759128 10/19/06 04:29 AM
stony-man Offline
Rob,
Here's my '92, with no lift, and stock wheels. You can see that there's all kinds of room left with 31s. I'm buying 33s this time around.
- '92 LWB V6 3.0 5 sp
33x10.5 BFG M/Ts & Bouncy seat
- '95 LWB V6 3.0 Auto (Scrapped)
- '05 Montero Limited. Bone stock <img src="/forums/images/graemlins/frown.gif" alt="" />
Re: Tire size for a GenII [Re: stony-man] #759129 10/19/06 04:38 AM
DavidG Offline
Stony, are your stock rims 15x6?
1997 Montero SR
Re: Tire size for a GenII [Re: DavidG] #759130 10/19/06 04:58 AM
Robb Offline OP
That looks great, did you crank the torsion bars in the front?
-Robb
1992 Montero (pics)
Re: Tire size for a GenII [Re: Robb] #759131 10/19/06 05:40 AM
stony-man Offline
Man, I'm embarrassed to say that I don't KNOW what width those wheels are. I had long thought they were 7". But I saw an auction on Ebay for a set like mine and they said they were 6". Mine are the same white steelies, I just painted mine black 6 years ago. I'm only going to get 10.5 width tires, so I shouldn't have to worry about it. Very slight crank on the Tbars...less than an inch. I'm going to crank them further after I put on the 33s, and get by like that until I can "schedule" a 2" body lift.
Re: Tire size for a GenII [Re: stony-man] #759132 10/19/06 08:04 PM
W
Winston Offline
Isn't the correct stock size tire 235 75 15? The 75 would make it a bit larger diameter over the 70 size tire. No?
'90 Montero XLS (Sold, sadly)
'95 Montero LS 160k
'03 Montero Limited 30k
Re: Tire size for a GenII [Re: Winston] #759133 10/19/06 08:38 PM
Mad_Scientist Offline
Yes, that's the stock size = 29" tire
PHP: 7.4.33 Page Time: 0.008s Queries: 16 (0.005s) Memory: 0.6409 MB (Peak: 0.7623 MB) Data Comp: Off Server Time: 2026-06-24 15:32:23 UTC
