Re: Front Wheel Bearings [Re: jfarsang] #759230 09/03/07 03:25 AM
Happy Birthday hazy_daze Offline
3 1/2 hrs ain't bad for the first go-round. Good job <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Front Wheel Bearings [Re: jfarsang] #759231 09/03/07 05:50 AM
DonM Offline
Saw two of them in Langley last few days. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Where were you in Langley. It was probably me that you saw. I live there and as far as I know there aren't any other Pajero's here.
1991 MITSUBISHI PAJERO EXCEED
Re: Front Wheel Bearings [Re: DonM] #759232 09/03/07 08:26 PM
jfarsang Offline
Last couple nights I was there. Saw one in Walnut Grove too.
NOTE ***************************
GEN II with SINGLE Piston calipers <<<<<<<<
Anyone with this combo looking to do the dual-piston upgrade need to do the following :
Caliper bracket is not the same.
1.Mounting holes line up properly but the holes where the brake line L-bracket mount on are different so you can just take off the L-bracket.
2.Dust/Heat shield. Make sure you take it off or at LEAST line up the bracket before you put on the new rotors/hub assemble as the new bracket will not fit around the heat shield.
Jesse (my buddy/mechanic) spent 2 hrs with a tiny stone grinder carving out enough of the shield so that the brackets can line up with the mounting holes.
Was a pain in the ass. We should have checked the mounting position of the new brackets but put everything all together ..
<img src="/forums/images/graemlins/lol.gif" alt="" />
So anyone running single piston wanting to go to dualies, make sure you measure up the brackets. <img src="/forums/images/graemlins/cheers.gif" alt="" />
... good.. bad.. I'm the guy with the gun.
94 Spacegear 2.8 - Build is on
89 Montero - Project
92 Pajero Exceed - Gone to a good home
92 Delica Chamonix - Gone to a good home
Re: Front Wheel Bearings [Re: jfarsang] #759233 09/11/07 05:19 AM
V
VERRELLI Offline
It might have been me in walnut grove.....I was visiting my brother.
Re: Front Wheel Bearings [Re: Neo] #759234 07/13/10 02:22 AM
I
IvanThomas63 Offline
I just done both weels myself,but did not feel like doing the race..I took to a shop they put all 4 races in for $15.00 and turned the rotors for $9.50 each. It sure runs down the road alot smoother.but had to replace a tire the loose bearing destroyed it inside the wall.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6123 MB (Peak: 0.6781 MB) Data Comp: Off Server Time: 2026-06-23 14:10:12 UTC
