Another obscure question. . . #759245 10/19/06 02:07 AM
AndyR Offline OP
I am so close to being done with my 1988 Trooper II, but there are a few remaining mysteries. First of all, I seem to have a "spare" wire coming out of the end of the fuel injector wiring harness. Here is a picture Photobucket . I also have a loose ground strap at the back of the engine that needs a home, and I cant find where it wants to go. Despite these things we tried to start it up, and it ran for about 20 seconds, then just died. It ran like it was "missing," but the timing looks good. I took the spark plugs out and cylinders 3 and 4 plugs were black and wet. We are having the injectors tested and cleaned, and our wiring looks good according to the shop manual, but if any of you have experienced this or have any ideas, I just might be able to finally finish this project. Thanks!
1988 Trooper II in the works.
Re: Another obscure question. . . [Re: AndyR] #759246 10/19/06 03:10 AM
bob large Offline
Well the plug in the pic looks like the one that goes on the distributor. But it should be in the back.
As for the grounding straps; one mounts on top of the valve cover, one on the back of the head, and one on the transmission/engine. Right in the middle bell housing bolt.
Steve C
Re: Another obscure question. . . [Re: AndyR] #759247 10/19/06 03:50 AM
JLEMOND Offline
THAT LOOKS LIKE THE ENG COOLENT TEMP SENSOR , LOOK UNDER THE INTAKE MANIFOLD RIGHT UNDER THE THERMOSTATE HOUSING AND SEE IF THAT ISNT WHERE IT GOES , THE SENSOR POINTS ALLMOST STRAIGHT DOWN JERRY
Re: Another obscure question. . . [Re: JLEMOND] #759248 10/19/06 04:02 AM
bob large Offline
yep, youre right. i'll change the pic to the corect one.
Steve C
Re: Another obscure question. . . [Re: bob large] #759249 10/19/06 06:36 AM
AndyR Offline OP
Actually Bob, I have the strap connected to the back of the head already (that is the one in question in my case) but I need to know where it mounts on the body or wherever. And thanks Jlemond, i'll check that plug as soon as I can.
Re: Another obscure question. . . [Re: AndyR] #759250 10/19/06 05:08 PM
Troopersphere Offline
The other end goes to the valve cover...
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Another obscure question. . . [Re: AndyR] #759251 10/19/06 07:09 PM
bob large Offline
one of the grounding straps goes from the valve cover to the body. one from the back of the head to the body. and the last goes from the bell housing to the body.
Steve C
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6165 MB (Peak: 0.6922 MB) Data Comp: Off Server Time: 2026-06-19 14:12:01 UTC
