gas gauge, oil temp gauge stoped workin.
#759810
10/22/06 06:56 AM
i was offroading today on cape cod. where i find a poor jeep xj lifted wiht 33s stuck in the sand. after pulling him out i mess around a little bit and go home.
Truck. 91 pickup... 3.slo.. automatic.. lifted blah blah blah.
so i'm drivin home and then i notice my oil temp is gone and my gas is totally empty... that cant be right. i pulled over and check every fuse. but they all looked good.. then as i was leaving i noticed that when i apply the break and try to shift from park to drive it dosent unlock the lock. and it took a few times to get the engine running cuz the battery light came up.. i am going to try a new battery in the morning and check all connections evverywhere.. any tips?
Re: gas gauge, oil temp gauge stoped workin.
[Re: philly]
#759811
10/22/06 07:20 PM
Check the ground point in the drivers side kick panel. Should be two white wires with black stripes going to a loop that's bolted to the metal. If that has come loose, it could cause what you're describing, since that's the main ground point for the cluster.
[Re: stock87]
#759812
10/22/06 08:12 PM
i've been checking stuff all morning and cant figure this out. what tells how much gas i have and what temp my oil is??
[Re: philly]
#759813
10/23/06 08:17 PM
well today i noticed none of the air/heat controls work.. soo iduno i have an extra thermostat im gona try.. gona get some prices on a fuel gauge sending unit and a oil pressure sender and hope that cures it!.. what about a relay somewhere??
[Re: philly]
#759814
10/23/06 08:46 PM
For starters, it's an oil pressure gauge, not temp.
Secondly, all those gauges share a common ground point, so it's about a one in one bazillion chance that all the senders failed all at once.
Take the kick panel off by the clutch pedal (below the fuse box) and check the ground point there. It should be securely attached.
If that doesn't solve it, you'll probably want to pull the cluster and check the wiring going into it.
[Re: philly]
#759815
10/23/06 08:47 PM
The gauges are basically ohm meters and the sending units are variable resistors. You can test the resistance of the senders. If they are in range, then there is no reason to replace them and the problem is in the gauge cluster. To test the gauges, you can tap the leads to the senders together and see if the gauges jump. (I've never done this, so someone correct me if this would damage the gauges, but I don't think it would)
88 Reg Cab 22RE 5spd, Mods: 94 bed, Sunroof, Bucket Seats, PW, PL, AC, Keyless entry, remote start. (Practically a Lexus)
[Re: BrokeAsAJoke]
#759816
10/23/06 08:50 PM
J Roll Me Over
The gauges are basically ohm meters and the sending units are variable resistors. You can test the resistance of the senders. If they are in range, then there is no reason to replace them and the problem is in the gauge cluster. To test the gauges, you can tap the leads to the senders together and see if the gauges jump. (I've never done this, so someone correct me if this would damage the gauges, but I don't think it would) THIS TEST WILL PERMANENTLY DAMAGE YOUR OIL PRESSURE GAUGE!!!!! Check the ground, as previously posted.
[Re: DRTDEVL]
#759817
10/23/06 10:01 PM
wow what a retard i am.. i checked fuses again today by pulling them each out.. and i dicsovered a burned one.. yesterday with a test light i did not find this. the gaugues fuse was burned out.. replece. and i got my gauges back. thanks for the responces guys
