1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg #759919 10/22/06 10:38 PM
Hi all,
I am a new owner of a very nice and clean 1994 4x4, 3.0L V6 extended cab, long bed Automatic.
I have been trying, in vien, to figure out why I get simply pathectic milage. 10-12/city 15-16/Hwy. I am in Canada where gas cost $1/liter or $3.80 an gallon. So you can see I'd rather get a little more then 200-250 miles on a $70 tank of gas.
I have checked the O2 sensor and it reads rich but the ECU does not seem to do anything about it. Does that mean I need to replace the ECU? Is there some other sensor that is part of this curcuit of decisions about fuel mix? (I'm not a mechanic)
Thanks
Best regards,
Glenn Schentag
Victoria, B.C.,Canada
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg #759920 10/22/06 11:42 PM
OOP'S Offline
Best I ever got was 18 MPG and that was with a manual tranny. Last time I checked mine it was 9 MPG!!!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg [Re: OOP'S] #759921 10/23/06 12:31 AM
half_fast Offline
I have an 88.... sounds about normal to me
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg [Re: half_fast] #759922 10/23/06 01:43 AM
No, that's real bad mileage. I get 20 mpg with my 88 V6 4Runner and 23 mpg on the highway. If your O2 is reading rich then the computer is adding too much fuel. You need to find out why. I would guess there is a vacuum leak somewhere making the computer think it's running lean and therefore adding fuel. Check the intake rubber hose for any hidden cracks. Clean the throttle body really good. Check to see if the catalytic convertor is getting clogged or damaged. The automatic trans won't get as good of gas mileage as the 5 speed but you should be getting closer to 17-19 mpg.
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg #759923 10/23/06 05:53 AM
Thanks for the tip. I'll check them tomorrow and let you know.
Cheers,
Glenn
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg #759924 10/23/06 02:49 PM
1
1FastSS Offline
13 -14 around town, 16 hwy, if I'm lucky......w/5speed.....
- Daily Driver - 2004 Corolla
- Off Road - 1992 Pickup SR5 3.0L 4x4
- Fun - 2001 Camaro SS (320 RWHP/330 RWTQ)
http://community.webshots.com/user/1fastss
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg #759925 10/23/06 02:50 PM
mt_goat Offline
Mine got about 12mpg city/16mpg hwy right off the showroom floor in 93 and did for 13 years. Best I've ever got was about 17mpg at high altitude (7000 ft).
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg [Re: mt_goat] #759926 10/23/06 04:37 PM
Wow, I can't believe you guys get that bad of gas mileage. My first Toyota pickup was a 1990 standard cab deluxe 4x4 3.0 5 speed with factory 31" tires and I did the 2-1/4" cat-back on that truck too. I average 21 mpg and 24 on the highway with that truck. Maybe the exhaust makes that big of a difference, I know the factory pipes neck down to 1-3/4" or less in the bends.
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg #759927 10/23/06 05:37 PM
stock87 Offline
The Auto is going to suck some mileage, but our 4Runner (94 3.0 5 speed) conistently got 17/20.
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: 1994 3.0L V6 4x4 Automatic - Sucks Gas big time 10-15mpg #759928 10/24/06 12:35 AM
trythis Offline
bad thermostat can create bad mileage, temp sensors.
PHP: 7.4.33 Page Time: 0.021s Queries: 16 (0.016s) Memory: 0.6289 MB (Peak: 0.7500 MB) Data Comp: Off Server Time: 2026-11-18 02:59:54 UTC
