power antenna ?'s #760354 10/24/06 05:39 PM
jaco Offline OP
the antenna mast on my montero is bent and doesn't retract properly. i wanted to buy a new mast, but it is $40 on ebay.
there are eclipse masts for much cheaper - $20.
does anyone know if eclipse mast would work on my 95 sr? are there any other cheap alternatives/places to buy?
thanks
Re: power antenna ?'s [Re: jaco] #760355 10/25/06 01:52 PM
dadrab Offline
I don't know for sure, but I wouldn't count on it.
You could check the part numbers or call a Mitsu store and ask.
Re: power antenna ?'s [Re: jaco] #760356 10/26/06 08:30 PM
Houston Offline
Check with your local Mitsubishi dealer, I don't remember paying much more than the dollar amounts for my replacement mast that I got for my Montero. Factory part, was not much money, way cheaper than a new ant/motor assembly too.
'92 SR Montero, Green, with 31" Yokohama Geolandar A/T Plus Tires, Mitsu factory fog light kit, on-board air compressor,Sony Radio and 10 disc changer. 213K and counting.....
Stock & Happy otherwise
Re: power antenna ?'s [Re: Houston] #760357 10/27/06 08:04 AM
jaco Offline OP
thanks for the replys guys.
i went to the dealer and they told me that a new mast is $80 (quite a bit for a little piece of aluminum.) the guy also told me that the masts are designed for specific models. so, can't use eclipse mast.
i'll just buy the ebay one.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.011s) Memory: 0.5999 MB (Peak: 0.6555 MB) Data Comp: Off Server Time: 2026-11-04 10:56:01 UTC
