bent crossmember #760886 10/26/06 05:11 PM
SPRaYeD Offline OP
i bent the crossmember that the driveshaft and exhaust goes through on my first gen trooper. anybody have any experience with fixing this? anybody replace this crossmember with something else?
Re: bent crossmember [Re: SPRaYeD] #760887 10/27/06 03:19 AM
ISueYou Offline
I did the same thing awhile back, got one pulled at a junkyard for $30. The worst part is going to be removing the bent one. You will want to use penetrant, a heat wrench, patience, and possibly a bible to avoid snapping the bolts holding it in.
good luck,
Jay <img src="/forums/images/graemlins/mrt.gif" alt="" />
1989 Trooper 2.8 V6 5-Speed(the daily driver)- Superwinch Hubs, otherwise Stock - $350
1990 Trooper LS 2.8 V6 Auto - Superwinch Hubs, otherwise stock....for now - $182.50
1983 Chevy Blazer - Stock - $150
No Car Payments - PRICELESS
Re: bent crossmember [Re: ISueYou] #760888 10/27/06 04:59 AM
mlclark Offline
Isuzu Moderator
He is talking about the next crossmember back from the tranny crossmember. The DS and exhaust are plumbed through it and it is welded to the frame.
If it is hopeless to straighten or you can't live with it, it is going to require cutting it out and rewelding a new one it.
You can go tube if you want. Just fab up mounts (bolt on or welded) and go from there. CPOM has some good pictures of what he did. While not specific to a trooper or that crossmember, it will give some ideas of how to do mounts and whatnot.
Good Luck,
Michael
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5918 MB (Peak: 0.6450 MB) Data Comp: Off Server Time: 2026-06-16 17:56:04 UTC
