88 4runner rear end replacement #761216 10/28/06 06:29 AM
dirtybikez Offline OP
hi ive got an 88 4runner v6 5speed and need to replace the rear end some dumb ass hit me and bent it. curious whether or not a 88 pickup rear end sould bolt up with no problems
Re: 88 4runner rear end replacement [Re: dirtybikez] #761217 10/28/06 05:39 PM
Adam F Offline
Yes it will. Any 84-95 4wd truck or 4Runner (up to '02' 4Runner) rear end will work.
Just make sure the ring and pinion is the same ratio (count the teeth)
97 4R, stock, daily driver
Re: 88 4runner rear end replacement [Re: dirtybikez] #761218 10/28/06 06:30 PM
Jake97T Offline
where are you located? little brother has a few...
Re: 88 4runner rear end replacement [Re: Jake97T] #761219 10/29/06 08:35 PM
im located in nor california and i think i found a rear end thanks
Re: 88 4runner rear end replacement [Re: dirtybikez] #761220 10/30/06 12:44 AM
Jake97T Offline
should find yourself a TRD tacoma rear axle...
Re: 88 4runner rear end replacement [Re: Adam F] #761221 11/05/06 09:30 PM
so if the 4 banger has the smaller third member and the v6 has the bigger third member will it make a difference
Re: 88 4runner rear end replacement [Re: dirtybikez] #761222 11/05/06 11:12 PM
Adam F Offline
Generally speaking, no. They are interchangeable. The V6 third has larger bearings and pinion gear, and a little different carrier. You would never know the difference if I had not told you.
Re: 88 4runner rear end replacement [Re: Adam F] #761223 11/06/06 12:43 AM
thanks just clarifying that they are interchangeable and that they fit the same. thanks for all of your help
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6194 MB (Peak: 0.7006 MB) Data Comp: Off Server Time: 2026-06-15 10:57:38 UTC
