Re: what solid axles to look for [Re: muddermontero] #761527 11/04/06 01:27 AM
redraider Offline
not to sound stupid or anything, but doesnt the gen 1 have a center diff? How do you take a center diff to a driver drop? I have plenty more questions for everybody since ive had mine about a year or so and am just getting into modding it. just wondering.
Re: what solid axles to look for [Re: redraider] #761528 11/04/06 02:01 AM
LandRaider Offline
Monteros have the front differential mounted to the drivers side.
Re: what solid axles to look for [Re: LandRaider] #761529 11/04/06 02:18 AM
sparkem Offline
When you hear people talk about gen2 center diff, the tcase acts like a diff so you can use 4wd on pavement, still driver drop though. Not center as in in the middle.
Re: what solid axles to look for [Re: sparkem] #761530 11/04/06 08:50 AM
redraider Offline
so the dana 44 out of a jeep will work for an 89 raider with the 3.0? coil or leaf spring suspension? would a dana 300 transfer case be a good choice or would there be too much modding to do to the frame? like i said many many questions
Re: what solid axles to look for [Re: redraider] #761531 11/04/06 08:58 AM
LandRaider Offline
You need to do some searching, and reading man.
You might be getting way way way too deep into this w/out learning enough up front.
FIrst off what are you going to hook that D300 up to? its a great case.... depending on what its being bolted to.
The wagoneer is leaf sprung if its in a stock configuration. You can build leafs or coils, and your 3.0 has nothing to do with anything. Not be rude, but you seem lost.
Re: what solid axles to look for [Re: LandRaider] #761532 11/04/06 10:38 AM
redraider Offline
forget that last post my bro was trying to mess with me
Re: what solid axles to look for [Re: redraider] #761533 11/06/06 10:27 PM
dannytuned Offline
Just want to chime in here to keep this thread alive. I've been considering a wagoneer axle swap, but I want to use the d44 rear also, in order to get 5.38 gearing. only thing is, no more abs, and the way i estimated it ran about $2700, might be a little too much. <img src="/forums/images/graemlins/shiner.gif" alt="" />
2001Sport 3.0-Headers-Cage-RoofChop-NP231/D300-D44/ARB-Ford9/Yukon/3Link-37's+H1's-PSC Assist-108:1
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6261 MB (Peak: 0.7007 MB) Data Comp: Off Server Time: 2026-11-16 01:26:30 UTC
