Rough idle / surging #761757 10/31/06 12:22 AM
At idle and applying light trottle, the engine feels like its about to stall then recovers. It happens about 2 a second. Once I apply a little more throttle, it goes away.
I've recently changed the plugs, cap, rotor, O2 sensor, air filter, oil. I also have a fuel filter and PCV valve that I'm going to replace. I didn't change the plug wires.
Does anyone have any ideas on where to start? Could it be a faulty sensor?
It's a 1991 Trooper 2.8L V6 Auto
Re: Rough idle / surging #761758 10/31/06 01:52 AM
Troopersphere Offline
mebbe a vacuum leak somewhere ?
Is it throwing any codes ?
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Rough idle / surging [Re: Troopersphere] #761759 11/01/06 12:38 AM
Mebbe check out the EGR circuit too...
C/YA!
Jeff
'88 Trooper
2DR LWB 4ZE1 5SP
bone stock DD
Re: Rough idle / surging [Re: Troopersphere] #761760 11/06/06 07:42 PM
I did check ou the vacuum lines. I'm not sure if the line was cracked before I started or after - all i know is i ended up snapping two of the vacuum lines trying to inspect them - they were amazingly brittle. I guess after 15 years, things are bound to fall apart.
After I replaced the vacuum lines, it did seem to get better, but has since returned.
What's a good way to check the EGR circuit? I pushed in the EGR valve, and it didn't take too much pressure to move, so i think that it's working okay. Could there be more to it that's causing the problem?
Thanks!
Re: Rough idle / surging #761761 11/06/06 08:58 PM
W
Wayne Offline
If they're that brittle, they might be leaking.
Get some starter fluid and start spraying carefully around the engine.
If you have a leak, generally the engine will race when the starter fluid hits it.
[color:"white"]? 04 Rodeo DI ?[/color] 75k mi, body damage on the 1st weekend I got it.
Re: Rough idle / surging #761762 11/06/06 10:24 PM
RT1 Offline
You need to check the EGR with the engine running. When you push it the engine should bog down which would indicate the exhaust gas is
getting to the right place. If it hasn't been cleaned in a while I'd recommend you take off the EGR valve and give it, and the port, a good
cleaning with a synthetic carb cleaner. They carbon up after a time and cease to function.
Vac lines can also develop small cracks that leak air in where it shouldn't be. It's a cheap fix just to get the right tubing and replace them all to eliminate that as a problem.
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
Re: Rough idle / surging [Re: RT1] #761763 11/07/06 04:56 PM
I
islandracer Offline
TPS maybe?
B.Y.E. ~ Back Yard Engineering
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6101 MB (Peak: 0.6878 MB) Data Comp: Off Server Time: 2026-07-13 21:32:52 UTC
