New engine noise just popped up!! #761770 10/31/06 12:24 AM
ciscofreak Offline OP
After rebuilding my 22RE with Darin's help (alot of help) I put 500 trouble free miles and then performed an oil/filter change. I then put another 500 miles on the truck which brings us to today.
I went out and started the truck and noticed what sounded like a metal to metal slapping sound coming on at 2K rpms lasting until about 2.4k rpms then either getting masked by the engine/exhaust sound or it goes away. It isn't really that loud but it is noticable in and outside the cab.
I first pulled the valve cover and checked my new EB RV head for broken valve springs, possible valve seat issues, and also valve clearences (incase the valves were slapping the pistons). Everthing there was fine.
I then ran a compression test and the results turned out fine (165,165,171,166).
What it sounds like to me is like a forged piston engine in the AM. Sound to me like I may have some piston slap. This of course is my uneducated guess but I've distinctly heard this noise before...
The number 1 and 3 spark plugs looked really good with number 3 being a little more "sooty" and number 4 being a bit more "sootier" (is that even a word?) than number 3. The cap and rotor are a slight bit worn so I plan on replacing those tonight to see if the ignition may be causing this. The timing checked out perfectly at 5 dergrees jumpered.
Anyone have any ideas? I dont have a mechanics stethescope yet but it sure seems to be coming from number 4.
Thanks,
Jake
Re: New engine noise just popped up!! [Re: ciscofreak] #761771 10/31/06 03:51 AM
missouriman Offline
did you look down in the front to see if a chain guide broke?
Re: New engine noise just popped up!! [Re: missouriman] #761772 10/31/06 04:42 PM
Yep, guides look good.
48 looks and no theories <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: New engine noise just popped up!! [Re: ciscofreak] #761773 11/01/06 08:49 AM
Davepet Offline
Put the business end of a long screwdriver on the area you want to hear & stick your ear on the handle.
Re: New engine noise just popped up!! [Re: Davepet] #761774 11/01/06 03:50 PM
Thanks, I'll try that when I get off work today to try and isolate where the noise is coming from.
Re: New engine noise just popped up!! [Re: ciscofreak] #761775 11/03/06 08:56 PM
Esquire812 Offline
Hey Jake, did you figure anything out on the noise problem yet? I should be able to come out some time this weekend and I'll bring my stethescope along for shitzngigglers. More than likely something simple that is being set off by vibration/harmonics at that speed. Guess we'll see huh?
I've unfortunately witnessed just about every internal problem there is for these injuns in the past so hopefully that can be ruled out right away.
88' 4x4 *22R-EB Gen II*
87' $Runner *22R-EB Gen I*
85' Sillyca 22R-Esq
Re: New engine noise just popped up!! [Re: Esquire812] #761776 11/04/06 12:05 AM
Right on man, I will be around all weekend. Just give me a call either at home or on my cell phone to make sure that I am at the house.
Re: New engine noise just popped up!! [Re: Esquire812] #761777 11/04/06 08:08 PM
DRTDEVL Offline
I was beginning to think you went to the toilet and fell in!!! <img src="/forums/images/graemlins/scared.gif" alt="" />
Where have you been hiding??? We all want to know... <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6220 MB (Peak: 0.7206 MB) Data Comp: Off Server Time: 2026-05-27 23:41:06 UTC
