Page 1 of 6 1 2 3 4 5 6
VW diesel swap #762265 11/01/06 05:52 PM
TexJeff87 Offline OP
So check out this link, coutesy of fellow wire menmber mojolounge....
web page
Yeah, it's for Zuks...but it also says they have the parts to do Yota's. Any interest?
If Mad Max had a 4runner...
Re: VW diesel swap [Re: TexJeff87] #762266 11/01/06 08:31 PM
ToyotaT Offline
I want a diesel so bad. Finally someone is making these adapters. Now if I just wouldn't have rebuilt my 22RE a couple years ago... The Germans know their diesels - it's no Cummins, but I think the 1.9 is a pretty good engine. If it can be tuned right it may not lack much at all in power either.
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: VW diesel swap [Re: ToyotaT] #762267 11/01/06 08:49 PM
Rauch_Off_Road Offline
What are the specs on the 1.9? Might still cost the same as swaping in a toyota diesel from overseas.
(aka suprathepeg, aka Sean)
Re: VW diesel swap [Re: Rauch_Off_Road] #762268 11/01/06 09:01 PM
Technical Specs: Engine
Standard Engine
1.9L I4
Cylinders
4
Horsepower @ RPM
[email]100@4000[/email]
Number of Valves
8
Torque @ RPM
[email]177@1800[/email] (foot/lbs)
Fuel Type/System
Diesel Engine / Electronic Fuel Injected
Turbo (yes/no)
Yes
Compression
19.0
Displacement
1896 / 116
Bore X Stroke
3.13x3.76
Valves Configuration
Single Overhead Cam
Supercharged
No
Re: VW diesel swap [Re: Rauch_Off_Road] #762269 11/01/06 09:14 PM
4Crawler Offline
I list some of the factory specs on my web page:
- http://www.4crawler.com/Diesel/index.shtml#EngineSpecs
Seems that the 1.9 engines are very detuned from the factory.
Re: VW diesel swap [Re: 4Crawler] #762270 11/01/06 09:28 PM
E
Eck Offline
I also drive a 2003 Golf TDI with the 1.9 engine. Changed the turbo, injectors and Dieselpump. All that with a software upgrade gets you ~ 180 HP (motor) and I limited the torque to 280ft.lbs. It's my daily driver so I don't want to stress the components too much but I have friends that are around 230 HP motor.
Best is, no smog check, exempt <img src="/forums/images/graemlins/smile.gif" alt="" />
92 Xcab V6 4x4 SR5 5sp., Detroit locker rear, lim. slip front, Warn hubs, H4's, electr. fan, eng. oil cooler, 1 lift, open cat.
Re: VW diesel swap [Re: Eck] #762271 11/01/06 10:05 PM
How much does it cost to get 180/280 out of that engine? I dont' think I would like it with the stock HP ratings but your setup sounds like fun. Did it change your milage a lot?
Re: VW diesel swap [Re: 4Crawler] #762272 11/01/06 11:27 PM
ToyotaT Offline
Can opening the injectors up raise the performance quite a bit, Roger?
85 Toy Pickup
Re: VW diesel swap [Re: ToyotaT] #762273 11/02/06 12:12 AM
4Crawler Offline
On the TDIs, folks put in the higher flow European injectors and chip the ECU for starters.
- http://www.vwdiesel.net/phpBB/
On the mechanical pumps on the 1.9D and TD, just cranking up the fueling at the pump works wonders. On the TD, intercooling and LPG fumigation work quite well.
Re: VW diesel swap [Re: 4Crawler] #762274 11/02/06 03:22 AM
A
allochris Offline
This is awesome. So does it mean it opens up options for swaping in a 1.9 tdi diesel in a 91' 4cyl pickup to run on a 2 tank system of diesel/svo or wvo?
To get best efficiency/mpg, what's best? 2lte-II or 1.9 tdi or some others i would know?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6457 MB (Peak: 0.7671 MB) Data Comp: Off Server Time: 2026-11-04 16:30:57 UTC
