Page 5 of 6 1 2 3 4 5 6
Re: VW diesel swap [Re: John Smith] #762305 01/19/07 05:54 AM
matts Offline
I have a dumb question. Has anyone looked into swapping a toyota diesel? While obviously parts would be a bit hard to come by in the states, would that hassle be worth the hassles *hopefully* avoided since the swap should be a bolt/plug in?
Frank
These guys are the best knowledge base on the Web I have found. They are some Toy diesel swapping fools. <img src="/forums/images/graemlins/lol.gif" alt="" />
http://toyotadiesel.com/forums/
There is a Japanese engine importer down in Atlanta or somewher near there that has half-cuts of Japanese Domestic market Hilux TD pickups with the 1KZ-TE 3.0 liter diesel. A half-cut gets you the whole front half of the vehicle for only $5800, and therein lies the rub. Most Toyota 4x4 hackers (like me) will find that a bit too rich for their budget. At first $800 for a VW TDI motor seems more in line with the budget ethos of "Early Toyota Trucks". Of course just as with a Chevy 4.3 swap, once you ad up all the bits and pieces you need in addition to the donor motor you are right up at $4000. The half-cut saves you from having to search for much of what you need including the motor, bellhousing, transmission, engine wiring harness, dash harness, computer, radiator, motor mounts, ect. The 1KZ-TE is rated at 116 hp and 232 ft.lbs. A chip upgrade is supposed to be able to push it up to 137 hp 290 ft. lbs. I think bigger power is available by stripping out the electronic injection and converting over to mechanical injection and an altered injection pump, but my diesel experience is next to nothing so I can only repeat what I've read in the Toyotadiesel forum.-- Matt
'89 4runner SR5, 3.0, auto (fun)
'93 xtra cab, dlx,3.0, 5spd (work truck)
Re: VW diesel swap [Re: salvo] #762306 01/19/07 07:05 AM
Dok Offline
A VW diesel is good to 3000 rpm... It falls on it's face rapidly afterwards.
You should be fine with a W56 and 4.10:1 gearing... If you have 33" tires, you will be cruising 70 mph @ 2500 rpm in 5th gear.
From what my tech's tell me the power band in the TDI is solid from about 1500 to 4500 rpm...
Also you can unlock a few HP by using this http://www.ross-tech.com/ we have a few customers that have used this and swear by it... Also alot of VW tech's use it as well...
The Ross-Tech stuff is awesome, I had a VAG-COM setup when I had my '96 Jetta.
How bout mass producing those CNC motor mounts! Now we just need someone to make wiring harnesses and all us lazy swappers will be set <img src="/forums/images/graemlins/cheers.gif" alt="" />
'87 4-Runner--DD/wheeler, 4.3 swap coming soon
'89 Supra--E85 powered 2jz NA-T Swap, 533rwhp 497ft-lbs
'89 Festiva, turboed BP swap powered by megasquirt
Re: VW diesel swap [Re: Dok] #762307 01/19/07 06:17 PM
dcg9381 Offline
I'm hanging in for a few more years until daimler chrysler starts putting more diesels into the Jeep series (Liberty, etc).. I'd love to see a 3.0-4.0L Diesel, especially a turbo coupled to manual transmission..
The VW swap is great - there's one guy on pirate who did it so cleanly I'd eat off it, but it's still a little anemic for all that work.
22REturbo.net
1988 4Runner
Re: VW diesel swap [Re: dcg9381] #762308 01/19/07 07:51 PM
matts Offline
The current Grand Cherokee is said to be available this year with a new Mercedes designed V6 diesel that puts out 376ft lbs torque while keeping emissions low enough for current California regs. Of course Toyota was selling the FJ80 Landcruiser with a 6 cylinder diesel as far back as 1990. The 1HD-FTE displaced 4.2 liters and was rated at 315 ft lbs and easily tweakable to 380 ft lbs. I still think the VW TDI swap is a good one for the mini trucks. It has a lot of support and trial and error already worked out. And after all, Germans invented the diesel. -- Matt
Re: VW diesel swap [Re: matts] #762309 01/20/07 01:11 AM
A
Andy87 Offline
Go for the Toyota diesel... The 1KZ-TE is by all accounts a good motor. Especially if you have a half cut, it will NOT be a hard swap, assuming of course you have the tools and some mechanical ability. My swap is not a 1KZ, and I had no half cut, and even it was not that hard; there is just a lot of little semi-difficult stuff to deal with. You just have to take your time.
'87 Xtra Cab, 4wd, 22r, 5spd
'92 Xtra Cab, 4wd, 2L-TE diesel swap, 5spd
http://toyotadiesel.com/forums/showthread.php?t=2502
Re: VW diesel swap [Re: Andy87] #762310 03/06/07 07:59 AM
A
allochris Offline
so, any update on this vw swap?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: VW diesel swap [Re: allochris] #762311 03/07/07 06:15 PM
Vanishing_Point Offline
How common are diesel toys in Canada? I live in MN, so a road trip wouldn't be out of the question.
America's first fourwheel drive was built in Mankato, MN by Ernest Rosenburger in 1908 who founded Four-Traction Auto Co. on Hickory Street. The company though successful closed in 1913.
Re: VW diesel swap [Re: Vanishing_Point] #762312 03/07/07 08:50 PM
ToyotaT Offline
Diesels are much more common in the Great White North. However..getting one registered in the States is likely where you will have the issue. Probably not impossible, but much more difficult than the drive North from Mankato <img src="/forums/images/graemlins/wink.gif" alt="" />
T.
85 Toy Pickup
89 block 30 over and EB RV head/261 cam
Re: VW diesel swap [Re: ToyotaT] #762313 03/07/07 11:23 PM
Rauch_Off_Road Offline
There really aren't a lot of them. Some old 2nd gen truck have a small diesel in them and a small few truck imported from Japan have diesels but they command a premium price.
(aka suprathepeg, aka Sean)
Re: VW diesel swap [Re: Rauch_Off_Road] #762314 03/08/07 04:53 AM
matts Offline
They let you import JDM vehicles into Canada? So you could buy a Nissan Skyline and register it?!! Land of the truely free! <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.008s) Memory: 0.6501 MB (Peak: 0.7574 MB) Data Comp: Off Server Time: 2026-11-17 11:29:01 UTC
