S10 Blazer
#762482
11/02/06 02:22 PM
wel my cousin has a 1990 S10 Blazer we are currently putting a 3 inch body lift on it but looking for a suspension lift soon my question is does it have front coil springs or a torsion bar i haven't been under it in a while and i haven't been able to see him in the last couple of weeks and is the back leafs over or under the axle
Re: S10 Blazer
[Re: rangermaniac]
#762483
11/04/06 09:50 PM
Simple questions with a simple answer. Have your cousin look under his truck. It has torsion bars in the front for sure.
As far as suspension lift kits go, check into Rancho, FabTech, Superlift, etc. and you're bound to find something. The kits I've seen consist of upper control arms and longer spring shackles. Good luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: S10 Blazer
[Re: rxinhed]
#762484
11/05/06 06:41 PM
Thanks and i went under it today and found out that it is torsion bars and i would have asked him but he doesn't know the difference between a coil spring and a leaf spring. Thanks though <img src="/forums/images/graemlins/cheers.gif" alt="" />
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.5921 MB (Peak: 0.6453 MB) Data Comp: Off Server Time: 2026-11-05 10:51:09 UTCValid HTML 5 and Valid CSS
