Re: 22RE Problems #762799 11/04/06 08:18 AM
Davepet Offline
I guess that is one of the things I need to learn how to do.
It's really easy & can often save a lot of head scratching:
http://www.off-road.com/toyota/tech/codes/index.html
Re: 22RE Problems #762800 11/04/06 02:54 PM
missouriman Offline
I would guess.
bad gas,
fuel pump pressure,
check the codes in the computer.
then pull the battery cable off and let it set for a few minutes.
or just try pulling the battery cable and reset the computer
wiggle the contections on the air filter box and the throttle, make sure that your oxegen sensor wire has not melted to the manifold.
Re: 22RE Problems [Re: missouriman] #762801 11/04/06 03:33 PM
solarcrew Offline
<img src="/forums/images/graemlins/confused.gif" alt="" />crank the truck up and start wiggling the wiring harness to the injectors.see if you get a miss or stutter while doing it.the harness is known to have a bad crimp connector in it. <img src="/forums/images/graemlins/cheers.gif" alt="" />
87'4runner-22re,5spd
Re: 22RE Problems #762802 11/05/06 08:54 AM
L
liam_the_red Offline
Something I ran into a while back was a vacuum leak in the air intake hose. A crack developed in the flexible part, and it was sucking air between the AFM and the intake plenum causing it to idle great and run at low RPM but stumble, then stall when you throttle up.
Just something simple to look at.
Tony
80 Toy - disassembled for refitting. '78 CJ-5 still alive. 74 GMC 1-ton full time 4X4,454, B&M TH350,Detroit lockers.
Re: 22RE Problems [Re: liam_the_red] #762803 11/05/06 09:55 PM
Thanks for all the great ideas of fixing the problem. I will have to try some of these and report back. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: 22RE Problems #762804 11/05/06 11:50 PM
22re Problem solved!! Woohoo.. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Thanks for all the help. If nothing else you guys learned me how to use the diagnostics on the truck. I will defenitely have to remember that for anything else that goes wrong.
Anyway, this is one for the membory banks just incase it happens to anybody else. The computer code kicked in with 4 blinks... Thermo sensor error. I stuck an extra sensor in it out of an old engine. and put the antifreeze back in... and it worked like a charm. No more stutters and not more sputters. I was really hoping it was something that i could fix with the extra parts I already had. Thanks again for all the help and idea.
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.6117 MB (Peak: 0.6812 MB) Data Comp: Off Server Time: 2026-11-02 00:56:40 UTC
