Re: Quadrajet Adapter [Re: BigJim] #762951 01/23/07 10:08 PM
I like Qjets, too, but the use of an adapter to a square pattern manifold is not as good a low speed adaptation as a square carb onto a spread bore manifold, because the secondaries get restricted by the adapter. If you don't need that last 1000rpm of engine range all that much, it will still work.
Re: Quadrajet Adapter [Re: fasteddy] #762952 01/24/07 11:50 AM
kc77cj7 Offline OP
My ideal manifold would be a spreadbore to accomodate the Q-Jet. However Offenhauser stopped making spread bore dual planes. I used a square bore manifold and bored the secondaries and primaries in the manifold to match a spreadbore carb, and made my own adapter. No one makes exactly what I needed so I made it my self... Here's sopme pics.
Sorry for the image size. I used a ball end mill to get the primaries to blend and a regular boring head for the secondaries. I used a piece of 1/2 alum. plate for the adapter. The manifold had plenty of material and bored fairly easily. I used a two-flute end mill to cut the perimeter of the adapter. One of these days I'll get a grinder to it and make it look pretty...
77 CJ-7 258 31" MTR's - now...
360, TF727, DANA 300, DANA 44's all sitting in the garage just waiting...
Re: Quadrajet Adapter [Re: kc77cj7] #762953 01/24/07 05:00 PM
BigJim Offline
Where there is a will to do a thing there is usually a way! And you have the proof. Good job!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5989 MB (Peak: 0.6530 MB) Data Comp: Off Server Time: 2026-06-10 04:23:02 UTC
