Re: '89 2.3l timing marks are gone... [Re: Richard Saylor] #762995 11/09/06 04:03 AM
O
ovrrdrive Offline OP
Thanks for the info here everyone. At least this gives him a place to start.
He's going to the junkyard in the morning to look at other trucks to see if he can find the marks. I have to work so I won't be able to go with him...
Some of the info above seems to contradict a little...
Are the degree marks on the drivers side or the passengers side?
Re: '89 2.3l timing marks are gone... [Re: ovrrdrive] #762996 11/09/06 05:28 AM
Happy Birthday Richard Saylor Offline
I'm 99% sure they're on the driver side.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: '89 2.3l timing marks are gone... [Re: islandracer] #762997 11/10/06 04:49 AM
JLEMOND Offline
YEP ISLAND RACER IS CORRECT ON THIS ONE ABOUT THE 2.3 TIMING MARKS , THEY ARE ON THE LOWER PLASTIC CVR IN THE EXACT SAME SPOT AS THE 2.6 , IN FACT THE CVRS ARE THE SAME PT NO, HOWEVER THE PULLEY /DAMPNER ASSY IS COMPLETELY DIFF, THE 2.6 USES THE DAMPNER THAT SLIDE ONTO THE CRANKSHAFT NOSE AND THE CENTER BOLT GOES IN TO HOLD IT ON , AND THE ACCESSORY DRIVE PULLEY BOLTS ON WITH 4 BOLTS , THE 2.3 HAS A HUB THAT BOLTS ON WITH THE SAME CENTER BOLT BUT THE ACCESSORY DRIVE PULLEY/PULLEYS (2) BOLT ON WITH 8 6 MM BOLTS AND THEY CANNOT BE INTERCHANGED BECAUSE OF THE TIMING GEAR SPACING .. JERRY
Re: '89 2.3l timing marks are gone... [Re: ovrrdrive] #762998 11/11/06 04:49 PM
I
islandracer Offline
0* on the tab is pretty much straight up (12 o'clock). The reason I say passenger side is because the tab reads from 0* to 12* BTDC from right to left. Anything right of 0* is retarded enough to run like crap on a stock engine.
......................Degrees: 12 8 4 0
Marks in increments of 2: ||||||||
............................<advanced|retard>
This is based on memory and if it serves me right the numbers are correct. Otherwise, whatever number is left of 0* will determine the increments per mark. *dont mind the dots before degrees, i used them to align the sketch...
B.Y.E. ~ Back Yard Engineering
Re: '89 2.3l timing marks are gone... [Re: JLEMOND] #762999 11/11/06 04:54 PM
I
islandracer Offline
Now that I think about it, I did try to use my 2.3 pulley on the 2.6 motor and it rubbed the lower timing cover and the ac/alt belts didn't line up. I ended up punching another mark on the center section of the "slipped" 2.6 pulley.
Re: '89 2.3l timing marks are gone... [Re: islandracer] #763000 11/12/06 04:45 PM
O
Thanks... That tells me exactly where the marks should be.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6197 MB (Peak: 0.7068 MB) Data Comp: Off Server Time: 2026-06-17 07:55:07 UTC
