Re: Raider V8 Project 345hp (added part 3 )
[Re: LandRaider]
#763081
11/08/06 04:29 AM
- it would be a long drive from Colorado I've got a D44 in the axle bank for you to install. - Does the D44 have similar ratio than Montero/Raider?
Raider 6.0 V8 386hp, 397ft lb, 3?exhaust, Megasquirt ECU, EDIS ignition, Innovate LC-1 WB Lambda, NV4500, NP241 with JB conversions ?super short? SYE kit
[Re: 777]
#763082
11/08/06 05:08 AM
Outstanding! Thanks for feeding us the details, with pics. Absolutely awesome! <img src="/forums/images/graemlins/kewl.gif" alt="" /> We'd love to be kept updated on this project...
Phil
[Re: 777]
#763083
11/08/06 05:58 AM
Does the D44 have similar ratio than Montero/Raider? We can put a 4.56 ring and pinion, in there. In the junkyard .. prob cost around 60-80 to get it out of there, and around 450-900 to rebuild, and regear it depending on locker choice. <img src="/forums/images/graemlins/kewl.gif" alt="" />
[Re: LandRaider]
#763084
11/08/06 06:06 AM
I second the tire smoke. You don't have to have a drivers seat to burn the tires do you?
'87 Raider w/rebuilt 2.6 Weber 32/36
[Re: Jamez]
#763085
11/08/06 01:59 PM
Very nice job here. I earn my living modifying things and it is nice to see someone who is not afraid to cut in to get a job done. If I were to critique the exhaust, running 2 1/2 back from the engine to a Magnaflow 12288 or similar that would give a 3" outlet would give you a more balanced flow with no loss of power. If the engine was another 20hp more then 2 3/4 front pipes would be in order. Magnaflow does make plenty of dual in dual out mufflers that would have lowered your workload a bit. But I do again have to say, nice job here. Good job getting the driveline to set in place and keeping the length in order. I am looking forward to how you go about your next step in axles.
[Re: OldColt]
#763086
11/08/06 02:29 PM
I have to drive to Denver on the 12th. I would sure like to see this rig. Where are you located?
Well on my way to becoming that eccentric old man in every town.(crazy as a s#@thouse rat) With a yard full of desireable old vehicles that tells you, Sorry they're not for sale..... Someday I'm going to fix them.
[Re: OldColt]
#763087
11/08/06 05:48 PM
If I were to critique the exhaust, running 2 1/2 back from the engine to a Magnaflow 12288 or similar that would give a 3" outlet would give you a more balanced flow with no loss of power. If the engine was another 20hp more then 2 3/4 front pipes would be in order. Magnaflow does make plenty of dual in dual out mufflers that would have lowered your workload a bit. But I do again have to say, nice job here. Thanks a lot for the comments. I understand what you are saying. Building the exhaust I also kept in mind that maybe one day I want to go for headers or/and different cam or/and blower, so I went bigger hoping that it could save me some time in the future, if I'd like to go for more power (there is never enogh power, you know).
[Re: highmtndesert]
#763088
11/08/06 05:50 PM
I have to drive to Denver on the 12th. I would sure like to see this rig. Where are you located? Send me your phone nr and I can call you...
[Re: 777]
#763089
11/08/06 08:38 PM
Interesting to see the exhaust running on the inside!!!
Is there any body lift done (didn't notice any reference to one) ?
When I put the 4.3 in, I needed a 2" lift to fit the GM trans/tcase.
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
[Re: don]
#763090
11/08/06 10:35 PM
When I put the 4.3 in, I needed a 2" lift to fit the GM trans/tcase. - The exhaust was actually outside after the floor was made - No body lift, that's why the floor is cut
