Page 9 of 10 1 2 7 8 9 10
Re: Raider V8 Project 345hp [Re: Lee N] #763121 11/24/06 05:18 PM
Alex Kogan Offline
I think you have a classic case of hydraulic dead heading. You are trying to push more fluid through the system than the lines and pump will handle. I think you could install a hydraulic pressure relief valve in the pump output line and cure it. The max system pressure is supposed to be about 1160psi with the pump deadheading against a gauge, so I'd use a 1000-1500psi adj. relief valve
I would think it's a situation of mismatched flow. If the extra flow has to be dumped over a relief valve, this will generate heat. The change in energy state (pressurized) to a lower state (unpressurized) has to be converted into something and that's heat. I'd say the solution is to either use matched components or a big cooler.
No, the effect would be quite opposite changing from pressurized to non-pressurized would actually cool it not heat it up. That's how refrigeration in general works. Loss of energy(depressurization) cann't coninside with acquiring of energy - heating up.
Pressure relif valve at the pump won't help/make any difference either, actually I'm pretty sure pump already has one at least I wouldn't make one without, since it will still keep system pressurized all the time. System pressure won't exceed pressure set by relief valve but who says it does.
08 PowerWagon (stock!)
Re: Raider V8 Project 345hp [Re: 777] #763122 11/25/06 07:20 AM
FrankR Offline
Risto (777) just left my house on his way through to NY and I had an opportunity to see his 6.0L Raider up close and personal..... all I can say is "WOW!" We went for a ride and all I could manage was laughter as my head was pinned against the headrest. That's a fast Raider! I guess I shouldn't be so surprised, since Risto spent his time in the States in Formula race car design engineering. Have any of you ever experienced leaf spring wrap under acceleration? <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
Here are some pictures taken at 11:00PM in the driveway:
I think Jimmy Hoffa is in here:
Ready for whatever:
Frank
Re: Raider V8 Project 345hp [Re: FrankR] #763123 11/25/06 07:45 AM
don Offline
Frank,
Must have been a great visit!
Truck looks FULL!
I noticed the carbon cannister is unconnected. Any details?
I like the laptop holder with the Garmin handheld GPS!
Spring wrap is an issue with the 4.3 as well, I've been avoiding hard acceleration...
Don `87 Mitsu 2dr, Rubicon survivor, GModified.
Re: Raider V8 Project 345hp [Re: FrankR] #763124 11/25/06 07:47 AM
Jamez Offline
Video speaks louder than text <img src="/forums/images/graemlins/notooth.gif" alt="" />
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: Raider V8 Project 345hp [Re: Jamez] #763125 11/25/06 08:27 AM
LandRaider Offline
IF my springs are bent, then I know his HAVE to be TOASTED!!! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Raider V8 Project 345hp [Re: FrankR] #763126 11/25/06 04:54 PM
7
777 Offline OP
Frank, if I knew that you put pics up here, I would have cleaned the car a bit <img src="/forums/images/graemlins/smile.gif" alt="" />
Not much to say... I didn't connect it at the beginning and this job has been pushed down and down in priority list. I have not done much research, how should it be connected. Normally there should be a valve controlled by ECU between canister and intake...
About springs.
I have replaced them for 3 times. First I put an extra torque bar, but still bent the springs. The solution came with D50 springs, that have 2 leaves coming to front pick up point and the leaves are 1 mm thicker
Raider 6.0 V8 386hp, 397ft lb, 3?exhaust, Megasquirt ECU, EDIS ignition, Innovate LC-1 WB Lambda, NV4500, NP241 with JB conversions ?super short? SYE kit
Re: Raider V8 Project 345hp [Re: 777] #763127 11/05/08 11:19 PM
BottomFeeder Offline
Anybody know the status of this project?
1990 Montero LS "Bottom Feeder" LWB, 33's, Cheapass Lift, 2" body lift, Dual BoUnCyS, Dual LSD's, KC's.
1995 Montero SR Complete LS interior swap and a BoUnCy from a 96 SR. General Grabber AT2's 33X12.5. 1.5" Body Lift
Re: Raider V8 Project 345hp [Re: BottomFeeder] #763128 11/05/08 11:38 PM
StockRaider Offline
2 years later I thought 777 posted an update... <img src="/forums/images/graemlins/frown.gif" alt="" />
Richard E
1989 Montero - Stock-ish
1983 Honda XL600R
Re: Raider V8 Project 345hp [Re: StockRaider] #763129 11/06/08 12:19 AM
Happy Birthday Chris_J Offline
He moved oversees if IIRC.
Re: Raider V8 Project 345hp [Re: Chris_J] #763130 11/28/10 10:53 PM
N
NickR Offline
Hate to revive an old thread, but does any body have pictures of his swap, all the picture links are dead.
1987 Dodge Raider, stick on 33", 2.5" BL, Con-ferr roof rack, Hella driving lights & pencil beam lights.
Stuff collecting dust in the garage
SR Axle
LSD 3rd member
Early Gen 1 Bouncy seat
Early Gen 1 two piece rear bumper
2 sets of SWB Gen I rear seat-belts.
Set of Aisin Hubs.
PHP: 7.4.33 Page Time: 3.595s Queries: 16 (0.005s) Memory: 0.6506 MB (Peak: 0.7803 MB) Data Comp: Off Server Time: 2026-06-21 18:45:42 UTC
