Re: Weld in body lift pucks? [Re: HCMP] #763190 11/06/06 06:29 PM
HCMP Offline
Smiley, I suck at the interweb so I e-mailed you the pics.
Re: Weld in body lift pucks? [Re: Starchild] #763191 11/06/06 06:46 PM
Bansil Offline
Andre,that will work good,there is a factory crossmember about 4" back from that so it shouldn't stiff'n the frame to much.I did the same thing on the rear of an old blazer so I could use short stock type bolts----no more broken bolts.
Using the stock bushings will be a pain,since they drop thru the frame.
Pick up some poly mounts for a heep and use them on top of the tubing.
Drill a larger hole in the bottom off the tubing so you can get a socket tape'd onto an extension up ther to tighten the bolts.
Bansil
98 Rodeo(hers)
00 Rodeo(his)
Lisa's Rodeo
Re: Weld in body lift pucks? [Re: Bansil] #763192 11/06/06 07:12 PM
Starchild Offline OP
'Great minds'???
Maybe on the same wavelength, but great? That remains to be seen <img src="/forums/images/graemlins/lol.gif" alt="" />
I really have had no issues with the side body mounts, at least that I know of <img src="/forums/images/graemlins/scared.gif" alt="" />, but I've only had the body lift on for two trail runs. I'll probably leave the side mounts alone for now, and I've got a master plan that will eliminate the rear mounts <img src="/forums/images/graemlins/evil.gif" alt="" />
I'm sure that once I get into the front mounts, I'll figure out the best (read: easiest) way to accomplish what I want. I'll be sure to post pics once I get to it.
Thanks for all the input <img src="/forums/images/graemlins/kewl.gif" alt="" />
<img src="/forums/images/graemlins/cheers.gif" alt="" />Andre
"SERENITY NOW!"
Re: Weld in body lift pucks? [Re: Starchild] #763193 11/06/06 07:52 PM
Smiley Offline
Hmmmmmm...
Even though the mounts on the Rodeo that are crushed-in just happen to be on the sides...
When I said "body-side mounts", maybe I should have said "the hollow raised/built-up metal flange-like thingies that are welded to the underside of the body, and support the weight that is resting upon each of the pucks" <img src="/forums/images/graemlins/wink.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
Six Isuzus, so far... still have three of them.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6101 MB (Peak: 0.6671 MB) Data Comp: Off Server Time: 2026-06-07 04:31:14 UTC
