front axle seal leaking #763473 11/07/06 11:52 PM
eightyeight Offline OP
when i did my sas about 6 months ago, i rebuilt the front axle. about 2 week ago i noticed the long side axle seal was leaking. not bad, but the bottom of the felt was wet with gear oil. i figured i had messed up the seal when i put the long side axle in (only had about 500 miles on the setup), so i took it apart and replaced the seal.
well, its leaking again. not bad. just a bit wet on the bottom of the felt. axle does not have a groove in it, and i was really careful installing the axle, so im pretty sure i didnt mess it up. any ideas? its not a huge problem, but it IS driving me nuts.
-matt
-'88 toy x-cab, SAS, chevys, gears, lockers, free tires, dented body mod.
-'87 4runner, bone stock DD
"It's OK to do stupid things, as long as you are not stupid about it."
Re: front axle seal leaking [Re: eightyeight] #763474 11/08/06 12:37 AM
4Crawler Offline
Make sure the axle shaft sealing surface is contacting the seal and not able to push in too far:
http://www.4crawler.com/4x4/CheapTricks/AxleRebuild.shtml#Martack
If that is OK, see if the axle shaft is centered properly, if not, adjust the steering arm shims.
Re: front axle seal leaking [Re: 4Crawler] #763475 11/08/06 01:05 AM
OOP'S Offline
Knuckles may not be centered. You need the SST to do it correctly.
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: front axle seal leaking [Re: OOP'S] #763476 11/08/06 01:13 AM
say what?
and arn't the steering arm shims just for kingpin bearing preload? er wait. you have the install shims evenly on both sides of the knuckle correct? cause i may not have done that..
Edit: 4crawler, on your martack article, thats a tack weld on the differential side of the axle am i understanding correctly?
-matt
Re: front axle seal leaking [Re: eightyeight] #763477 11/08/06 02:11 AM
OOP'S Offline
say what?
No, the bottom shims are for centering the knuckle. The top shims are for adjusting he preload. You cannot go by what shims are correct for one will make them correct for the other. The last time I rebuilt my front I was able to use the SST and both sides took different amouts of shims. One of the measurments you take is the distance between the mounting surfaces on the top and bottom of the knuckle. They were not the same on the PS and DS knuckle.
Click on this link and go to page FA-54 and it will show you the SST I used and the correct way to set the knuckles up. This is the FSM.
http://www.lukemiller.org/toys/1985_toyota_4wd_front_axle_FSM.pdf
David Fritzsche
Roseville, CA
Re: front axle seal leaking [Re: eightyeight] #763478 11/08/06 02:16 AM
4Crawler Offline
Yes, used in place of the internal clip in the Birfield. Makes it much easier to work on the axle when it can just slide in and out of the Birf.
Re: front axle seal leaking [Re: OOP'S] #763479 11/08/06 02:39 AM
OOP's- sweet dude, i most likely set up my knuckles completly wrong. all i did was set the preload. will have to check into that.
4crawler- yeah, ill have to do that, seems like a good idea.
thanks guys
-matt
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6218 MB (Peak: 0.7134 MB) Data Comp: Off Server Time: 2026-05-30 13:51:11 UTC
