Page 4 of 16 1 2 3 4 5 6 15 16
Re: OT Plane on a Treadmill [Re: Roll_me_over] #763574 11/08/06 08:10 PM
bretwalda Offline
I still stand by my original post. No where does the riddle say the aircraft is even running. It says it is "standing". If it is standing, and the conveyor moves according to the planes movement - then nothing is moving - the conveyor or the plane.
It will never move - as soon is movement is detected the conveyor moves keeping it back zero point. So the conveyor would crawl at a barely detectable speed.
The better way to word the riddle would be to ask if a plane landed on a conveyor the length of the plane running at the same speed as the ground speed of the plane - would the plane run off the conveyor?
Yes.
Its all about wind speed over the wing. Everything else is irrelevant.
concreteprinter.com
Re: OT Plane on a Treadmill [Re: Roll_me_over] #763575 11/08/06 08:42 PM
bretwalda Offline
The plane's propulsion is pushing against the air, not the ground.
But to take off its True Airspeed has to match its TakeOff speed....
True airspeed (TAS) is the speed of an aircraft relative to the airmass in which it flies, i.e. the magnitude of the vector difference of the velocity of the aircraft and the velocity of the air. Under zero wind conditions and in horizontal flight, this is equal to the speed over the ground. Under wind conditions an estimation of the wind is used to make a windspeed vector calculation that computes an estimated ground speed from the true air speed and a wind correction angle to maintain the desired ground track.
It will actually MOVE foward on the treadmill against the direction even though the treadmill is going backards, and create airspeed
No - the riddle says - "This conveyor has a control system that tracks the plane's speed and tunes the speed of the conveyor to be exactly the same (butin the opposite direction) instantly."
The plane would need sufficient air speed to lift off, and thats irrelevant to ground speed
To get to sufficient air speed the plane needs to move through linear space for air to pass over the wing (assuming no wind) If the conveyor negates any forward movement of the plane it is not moving through space. The engines are producing thrust, but the conveyor is the one consuming this work - not the plane.
Think about it.....If the plane is not strapped down it will roll forward
ARGHHHHHHHHHHHHHH! How can it move forward if the forward movement is matched with equal and opposite movement from the conveyor??
I have 20HRS solo time. So you can't argue with me <img src="/forums/images/graemlins/lol.gif" alt="" />
concreteprinter.com
Re: OT Plane on a Treadmill [Re: bretwalda] #763576 11/08/06 08:58 PM
LandRaider Offline
Because it is NOT attached to the conveyer. the wheels provide minimal rolling resistance. The conveyer CANNOT tether a plane by its wheels.
The conveyer can match speed of the plane, but it will have 0 effect on the plane.
Re: OT Plane on a Treadmill [Re: LandRaider] #763577 11/08/06 09:59 PM
NathanC Offline
OK, If I'm running on a treadmill, and the treadmill is matching the speed at which I'm running then I don't move.
Now, lets say that I decide while I'm running, that I want to "walk" down the handrails using my arms. Does it matter how fast the treadmill and my feet are moving? NO.
The plane is not moving because of it's wheels, it's moving because of the engines acting against the air.
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: OT Plane on a Treadmill [Re: LandRaider] #763578 11/08/06 10:04 PM
stony-man Offline
So I was right with my initial idea, it won't move, right? LOL <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" /> Frank or Eddy will have to build us a giant treadmill for testing.
Re: OT Plane on a Treadmill [Re: stony-man] #763579 11/08/06 10:35 PM
bretwalda Offline
NO NO NO Yes it will fly people.
My best example.
Go buy a cheap RC plane at Harbor Freight. On a windless day, run the thing at full throttle, hold it above your head and let it go.
You should probably bring bandaids.
You have to THROW it or run with it. So that the velocity of wind over the wings matches its takeoff speed. There has to be forward motion through linear space for the air to move over the wing.
concreteprinter.com
Re: OT Plane on a Treadmill [Re: LandRaider] #763580 11/08/06 10:45 PM
bretwalda Offline
It is attached figuratively speaking, by gravity until its take off speed (airspeed over the wing needed to produce lift) is reached. On a windless day, ground speed will have to match T/O speed (or more precisely TAS required for takeoff) for the plane to take off since the air is stationary. In this case, ground speed is zero.
Any forward momentum from the thrust, is negated by an equal and opposite momentum of the conveyor. We need momentum to move the plane through linear space so that air can move over the wing. It aint going anywhere. And if it was calibrated exactly, you would hardly see the conveyor move.
I am going crazy <img src="/forums/images/graemlins/zombie.gif" alt="" />
Re: OT Plane on a Treadmill [Re: bretwalda] #763581 11/08/06 11:36 PM
NathanC Offline
But the wheels aren't driven! They're just big casters basically. The force of the conveyor only spins the wheels. The thrust of the plane acts on the air and propels the plane forward. The conveyor has no impact on the relationship between the air and engines.
'88 Mighty Max
Re: OT Plane on a Treadmill [Re: NathanC] #763582 11/08/06 11:47 PM
DougH Offline
Mitsubishi Forum Moderator
This is a good brain teaser. After thinking about it for a while I think I was originally wrong, and that if the treadmill was the length needed to take off then the plane will get in the air.
If it doesn't blow up the landing gear first!!! <img src="/forums/images/graemlins/scared.gif" alt="" />
DougH
1995 SR - RIP
1993 RS - RIP
Re: OT Plane on a Treadmill [Re: DougH] #763583 11/09/06 12:00 AM
DaphneD Offline
So, back to my point...
Then why is the treadmill system not employed at airports or aircraft carriers? Or is this treadmill infinitly long or just as long as a normal runway?
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6521 MB (Peak: 0.7645 MB) Data Comp: Off Server Time: 2026-06-06 21:37:01 UTC
