Page 5 of 16 1 2 3 4 5 6 7 15 16
Re: OT Plane on a Treadmill [Re: DaphneD] #763584 11/09/06 12:07 AM
PartyTruck Offline
I see a whole new future in aviation, all planes will take off on a treadmill doing full thrust and the treadmill going full blast backwards and then...........slam the brakes on the treadmill and you can fly anything with thrusters on it. My house even. <img src="/forums/images/graemlins/smile.gif" alt="" />
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: OT Plane on a Treadmill [Re: DaphneD] #763585 11/09/06 12:11 AM
LandRaider Offline
So, back to my point...
Then why is the treadmill system not employed at airports or aircraft carriers? Or is this treadmill infinitly long or just as long as a normal runway?
Because it neither helps nor hurts. It's irrelevant to the plane, and the air.
Re: OT Plane on a Treadmill [Re: LandRaider] #763586 11/09/06 01:08 AM
Jamez Offline
So would it be incorrect to state that while the wheels are supporting at least more weight than is negated by lift, the plane IS actually tied to the ground by the wheels? I understand the airspeed and groundspeed thing, but if a plane was sitting on a treadmill and it started moving backwards, the plane would move with it because of what I stated above, right? For those of you saying it would take off, it would only make sense to me if the treadmill itself moved through space with the plan on top to allow for the required airflow across the wings. The engines produce thrust, but they don't produce a cocoon of airflow around the entire aircraft.
'87 Raider w/rebuilt 2.6
Weber 32/36
Re: OT Plane on a Treadmill [Re: LandRaider] #763587 11/09/06 01:17 AM
PartyTruck Offline
BINGO The plane just moves forward and off the conveyor belt and the ECU for the belt completely melts down out of amazement. Disbelievers should try out flying.
Re: OT Plane on a Treadmill [Re: PartyTruck] #763588 11/09/06 02:13 AM
NathanC Offline
But what if there were snakes on the plane?
'06 Dakota QC 4.7 6sp 4x4
'88 Mighty Max
'77 KZ1000 fun old bike
Re: OT Plane on a Treadmill [Re: NathanC] #763589 11/09/06 02:26 AM
stony-man Offline
<img src="/forums/images/graemlins/lol.gif" alt="" /> Jeeze Nate, this is complicated enough already. <img src="/forums/images/graemlins/lol.gif" alt="" />
Here's some comments from a "smart guy" friend of mine. I asked him in an email what he thought of the original question:
Well...first thing is this: the plane would have to be moving, not standing to even attempt to take off. A plane doesn't lift off the ground due to speed. Speed is just what helps airflow come across the wings to provide lift. If it were moving forward allowing air to pass over the wings than lift could be acheived. If the ground speed is 100 mph forward but the conveyor is going 100 mph backwards, then the true ground speed would be 200 mph but no forward motion hence no airflow over the wings which is what is needed for lift. The only thing that has enough power to overocome ground speed creating flow over the wings is a jet engine ( huge jet engine) in a very small plane. F14, F15 that could power the plane forward (air speed) without needing wheels on the ground (ground speed). Most all planes are not powerfult enough to overcome the weight and drag on the plane by engine alone. I say if you consider the plane is a normal passenger plane... it's not going anywhere but the wheels will be seeing lots of mileage.
Re: OT Plane on a Treadmill [Re: Roll_me_over] #763590 11/09/06 04:14 AM
Roll_me_over Offline OP
Of course it will fly. The plane is producing thrust at the body, not the wheels. It doesnt matter whats going on at the wheels. If it was a car with wings, NO it wouldnt take off.
or better yet...
02 Ford F-250 4X4 PSD...zero body damage
67 Weimann 18' Jet boat...zero body damage except for the trailer drags on the ground from time to time
Re: OT Plane on a Treadmill [Re: stony-man] #763591 11/09/06 04:32 AM
FrankR Offline
Stony, your "smart guy" friend needs a little help here. <img src="/forums/images/graemlins/wink.gif" alt="" />
Nope - if (as someone suggested) an unpowered plane was tethered and facing a 100mph wind, it would begin to fly in place. If at the moment of lift-off you brought the engine up to speed and released the tether - and if the engine was capable of moving the plane at 120mph (air speed), the plane would move forward into the wind at 20mph (ground speed) or 120mph (air speed). If the plane could fly as slowly as 80mph (air speed) and the engine set at that power rate, if faced with a 100mph headwind, the plane would still fly, but it would move backward (relative to the ground) at 20mph.... but would still be flying. The same is true of boats moving against a current. I once trolled for 3 hours at an indicated 7 knots in a southerly direction at the edge of the Gulf Stream (flows northerly - usually at a rate of ~3 knots), which unknownst to me was moving at a rapid clip that day... after 3 hours I looked at the Loran and found myself 8 miles further North than my starting point. <img src="/forums/images/graemlins/scared.gif" alt="" /> That sort of stuff makes you question your sanity until you understand the forces at work.
Yes, it does..... but it's called "air speed" (ground speed is irrelevant).
Yes, ground speed is used to achieve air flow over the wing, but is assisted by available wind speed... which is why airplanes take off into the wind..... and headwind speed is deducted from necessary ground speed required to achieve takeoff speed (always measured in air speed).
Wrong again..... "wheel speed" would be 200mph but "ground speed" relative to the fixed-earth (not the conveyor belt) would still be 100mph. Forward motion relative to the conveyor belt would be 200mph and "ground speed" relative to the frame of the conveyor and the earth would be 100mph. Assuming no wind, "air speed" would also be 100mph.
I wonder how those little Cessna 150s can fly without a jet engine? <img src="/forums/images/graemlins/lol.gif" alt="" />
Yes, the wheels will see a lot of mileage, but it dang sure will fly. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Curtis gave the simplest answer - the plane moves at 100mph relative to the earth, the conveyor goes 100mph in the opposite direction and the wheels turn at 200mph.... it's as simple as that.
If the brakes are applied, the airplane goes where the conveyor takes it.... once the brakes are released and power is applied, the plane moves against the air - just like a boat propeller moves a boat through the water (assuming zero frictional losses in the wheel bearings).
If the conveyor had any bearing on the plane's motion, we could fly a plane at 100mph onto a conveyor belt which was moving at identical speed in the opposite direction and have it stop on a dime (if the occupants could stand the G forces). We could almost do that (except for momentum) if the brakes were locked, but that would be called a "crash" instead of a "landing". <img src="/forums/images/graemlins/lol.gif" alt="" /> Now, if we turned the conveyor belt in the same direction and at the same speed as the plane, we could land the plane without the wheels turning at all. <img src="/forums/images/graemlins/kewl.gif" alt="" />
During WWII - when rubber was scarce and tires were rationed - my father watched planes coming into some of the Phillipine Island landing strips and burn off much tread as the tires came up to rotational speed from zero. He wondered why he couldn't install an electric motor with a frictional or viscous drive to turn the wheels at landing speed, negating the rubber loss on each landing and greatly extend tire life. Unfortunately, when the war was over, he returned home to find the idea patented.
Anyway, the plane flies off the conveyor belt as pretty as you please - so long as the wheel bearings don't seize. <img src="/forums/images/graemlins/shiner.gif" alt="" />
Frank
Re: OT Plane on a Treadmill [Re: FrankR] #763592 11/09/06 05:17 AM
stony-man Offline
Well, by "smart guy", I only meant smarter than me. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: OT Plane on a Treadmill [Re: FrankR] #763593 11/09/06 05:17 AM
LandRaider Offline
Frank
Thank you Frank. Anyone who does not understand this needs to REREAD the post, and think about it for a while. Its stated VERY clearly how, and why the plane will be able to lift off, and fly away.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.005s) Memory: 0.6654 MB (Peak: 0.7799 MB) Data Comp: Off Server Time: 2026-06-07 03:43:17 UTC
