Page 12 of 16 1 2 10 11 12 13 14 15 16
Re: OT Plane on a Treadmill [Re: LandRaider] #763654 11/10/06 10:36 AM
LandRaider Offline
OOps double treadmill post.
Re: OT Plane on a Treadmill [Re: bretwalda] #763655 11/10/06 01:26 PM
FrankR Offline
Picture the glider with gear wheels - and the treadmill with matching gear tread. When the planes touches they mesh perfectly.
It doesnt matter what speed it comes in - wheel bearings frictionless, perfect contact i.e. no skip or slip of the wheel - it will stop do you concur?
Now you're changing the parameters.... again. <img src="/forums/images/graemlins/lol.gif" alt="" /> In this case, the gears on the plane's tread will mesh with the teeth on the treadmill. The only way to gain sychronization would be to have the plane's wheels driven. The drive mechanism would have the effect of locking the wheel to the treadmill and the result would be a broken gear as the assembly shears from the airplane on impact. The gear would stop, but the rest of the plane would continue down the treadmill runway. If the gear was strong enough, everything would stop if the force applied by the treadmill equalled the force of the plane..... BUT.... that scenario would not be considered WHEELS..... it's now GEARS!!
No, the glider won't stop - wheels or no wheels. All that will happen with a glider on wheels, is the wheels will now turn twice as fast when the treadmill matches the glider's speed in reverse direction.... if the treadmill direction and speed is the same as the glider, the wheels don't turn at all.
Momentum is mass times velocity correct?
So the plane 100 lbs.
Velocity of the plane matches velocity of treadmill. They cancel out. Zero.
100x0 is zero - no momentum.
No momentum means no forward motion.
Right there is where you're getting wrapped around the axle, Phil. In order for energy to transfer, force must be applied by one thing acting on another. If the treadmill had a 20' high steel wall mounted to the tread that moved as a part of the tread in the opposite direction to the plane's travel.... and if the mass of the wall was the same as the plane.... and if the wall was moving at the same speed as the plane.... and if the treadmill decoupled from its drive mechanism just before impact (better if the wall decoupled from the tread via frictionless bearings)..... and if the plane flew into the wall......... then yes, energy transfer would balance and everything would come to an instant stop. But what you have in the original parameters is an inability for the treadmill to transfer force to the plane equal to the plane's thrust because the bearings allow the wheels to turn.
Think of it like getting stuck on slick wet grass or clay - no matter how fast you spin the wheels, you can't transfer power and when you can't transfer power laterally, no movement can be expected.
You should ponder why airplanes have wheels....... one reason is to prevent (or control) energy transfer on landing. Otherwise, the event becomes a crash where the energy of the flying airplane is absorbed by the earth and the resulting force destroys the plane and kills the occupants. The second reason is to negate frictional forces between the airplane and the ground.... to allow the thrust of the airplane's engine to build momentum and move the plane over the ground at an increasing rate of speed in order to achieve enough air speed over the wing to generate the amount lift needed for takeoff.
Frank
Re: OT Plane on a Treadmill [Re: LRJ4x4] #763656 11/10/06 05:54 PM
I just asked a Navy Pilot with a Masters in Aerospace Engineering. He is going to e-mail me a reply <img src="/forums/images/graemlins/lol.gif" alt="" /> <img src="/forums/images/graemlins/patriot.gif" alt="" />
Gee whiz! I hope he gets the right answer.
I'll ask the guy with the "homeless and hungry" sign down the street. I think he has knowledge of such voodoo. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: OT Plane on a Treadmill [Re: cmonty72] #763657 11/10/06 06:52 PM
onebadtrooper Offline
I'll say it again... the plane will take off <img src="/forums/images/graemlins/lol.gif" alt="" />
Try this.
Put on a pair of roller skates and get on a treadmill.
Then have a rope tied to somthing in front of the treadmill
Try to pull your self forward.
Re: OT Plane on a Treadmill [Re: onebadtrooper] #763658 11/10/06 07:08 PM
lee_raider Offline
Or even better yet..............
Try this.
Then have a jet engine tied to your head. See if you stay motionless once it is fired up. <img src="/forums/images/graemlins/lol.gif" alt="" />
The only time I may have seen something similar to that, was .....Wile E Coyote in a cartoon once. And he only stayed motionless for a second, then took off. And of course...... promptly fell off a cliff.<img src="/forums/images/graemlins/drunk.gif" alt="" />
But yes, he did take off. <img src="/forums/images/graemlins/smile.gif" alt="" />
Two MRI's and a CAT scan....it's confirmed. I'm just not right in the head.
Re: OT Plane on a Treadmill [Re: bretwalda] #763659 11/10/06 07:43 PM
Oyaji_Jon Offline
You said it...
M=mv. In this case, you are saying the v = v(plane) - v(tread). In order for this to be the case, the wheels MUST have an effect on the forward motion of the plane. We have all agreed that the wheels are FREELY spinning, so how can they? The plane's velocity has an effect on tread velocity because that is how the original problem is stated.
New equation: F=ma
Force acting on wheel:
F1 = m(plane)*g {downward}
F2 = m(plane)*g {upward because ground pushes back equally}
F1=F2 and cancel out
F3 = m(wheel)*a(wheel) {rotational acceleration of round mass due to contact with the treadmill when it moves. This acceleration is purely rotational and has minimal effect on the plane because of a small amount of lateral translation while it accelerates. Remember: FRICTIONLESS bearings}
Forces on plane:
F3 = m(plane)*a(plane from thrust) {forward resulting in the only force acting on the plane and causing forward motion}
Can you argue that a force that doesn't act on the plane alters it's stationary status? Just curious... <img src="/forums/images/graemlins/notooth.gif" alt="" />
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: OT Plane on a Treadmill [Re: lee_raider] #763660 11/10/06 07:59 PM
Alex Kogan Offline
Phil just thik about it. Plane's engine creates a thrust - a force applied in one direction. Bearings are frictionless as we agreed. So there is no force opposing thrust from the engine. Just remember the phisics: If object is exposed to force acting in one direction without opposing force reacting, object will move/accelerate. F = m*a.
How about if we put rocket on wheels onto treadmill. Is it going to move? Or for example, if we magnetically levitate plane just above the surface just maybe 1/16" will it fly away?
Yes it will!
08 PowerWagon (stock!)
Re: OT Plane on a Treadmill [Re: Alex Kogan] #763661 11/10/06 10:28 PM
PartyTruck Offline
I think this riddle with the plane, the glider and the helicopter in the elevator have all the same answare as the one I'm throwing at you now:
"How long does it take a woman to reach orgasm?"
Solution will be posted later
1987 SWB Pajero 2.5 TDI on 31" rubber waiting for a hip replacement and bigger shoes
Re: OT Plane on a Treadmill [Re: PartyTruck] #763662 11/10/06 10:36 PM
Women can have orgasms? <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: OT Plane on a Treadmill [Re: PartyTruck] #763663 11/10/06 10:41 PM
Oyaji_Jon Offline
That's easy, there is no answer. There is no such thing. It's a myth to drive us crazy, keep us feeling guilty and cause us to buy the ladies whatever it is that they want... <img src="/forums/images/graemlins/notooth.gif" alt="" />
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6638 MB (Peak: 0.7751 MB) Data Comp: Off Server Time: 2026-06-20 21:43:10 UTC
