Page 16 of 16 1 2 14 15 16
Re: OT Plane on a Treadmill [Re: StockRaider] #763694 01/29/08 04:55 PM
Tag Offline
Maybe but all the people inside are going to puke all over the place. <img src="/forums/images/graemlins/lol.gif" alt="" />
89 2dr 3.0 AT, manual hubs. 33x12.5 MT
gen 2 coils,Cranked front tbars
Dons rocker protection, Front/Rear Bumpers. ARB rear locker, 2" BL, Beefed up skid plates/trailing arms. Gen II uca, 2 Bouncy seats www.youtube.com/TagGeorge
Re: OT Plane on a Treadmill [Re: Smiley] #763695 01/29/08 05:06 PM
stony-man Offline
Can someone loan me a smiley that's flipping the middle finger please?
I'm not up for a trip to Central Ohio right now -- would a photograph do?
<img src="/forums/images/graemlins/pfft.gif" alt="" /> <img src="/forums/images/graemlins/lol.gif" alt="" />
<img src="/forums/images/graemlins/smile.gif" alt="" />
LOL Just send that straight over to Rich. <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: OT Plane on a Treadmill [Re: stony-man] #763696 01/29/08 05:10 PM
DAAAAAAANG that pic of whats her legs is nice! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: OT Plane on a Treadmill [Re: cmonty72] #763697 01/30/08 08:47 AM
DamKia Offline
Kia Moderator
My 2 cents worth.
The engines produce thrust which propels the plane forwards (every action has a equal and opposite reaction). Therefore the ONLY answer is the plane will push itself off the conveyor belt, IRRESPECTIVE of the conveyor belt and tire speed of the aircraft. Conveyor belt speed is irrelevant.
The thrust developed by the engines will only provide lift to the immediately adjacent areas in the wash of the engine (if they are present), ie the airflow at the tip of the wing is minuscule from the engine in relation to the wing root area (wing mounted engines) or in some aircraft, simply the area adjacent to the engine. The lift is generated by the engines pushing that large amount of aluminum until all the surfaces have enough airflow over them to generate lift.
The original question should probably have been asked like this:
"Will an aircraft that is tethered to the ground(equaling the zero ground speed of the original Q) lift off the ground under full throttle.
In this cas the answer is NO, as there is insufficient airflow over ALL the lifting surface (wing roots through to tip) to generate sufficient lift.
All the naysayers???
Explain this....
Engines so far aft of the wing as to have little effect on the airflow directly on the main wing (ground staff can safely walk around the front of the aircraft with the tug attached). All they are doing is giving a "rear wheel drive" boot up the bum to the aircraft to generate enough speed to get the airflow velocity to what it needs to take off.
Short answer, aircraft on conveyor belt will advance fwd and eventually off the conveyor belt regardless of belt speed, therefore given a long enough conveyor belt, yes it will take off
Re: OT Plane on a Treadmill [Re: DamKia] #763698 01/30/08 06:19 PM
LandRaider Offline
My 2 cents worth.
The engines produce thrust wblhablhablahablhabalhor belt regardless of belt speed, therefore given a long enough conveyor belt, yes it will take off
This is all what we have already explained. You logic is perfect. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: OT Plane on a Treadmill [Re: LandRaider] #763699 01/31/08 07:00 AM
LandRaider Offline
If anyone is still in doubt of this, please watch mythbusters. Plane defiantly takes off.
Re: OT Plane on a Treadmill [Re: LandRaider] #763700 01/31/08 07:15 AM
kewlynx Offline
Daz episode 97 btw. More readin'.
http://www.straightdope.com/columns/060203.html
**ubi apis- ibi salus**
Re: OT Plane on a Treadmill [Re: kewlynx] #763701 02/01/08 12:37 AM
sparkem Offline
Even the guy driving the plane thought it would not take off. Why did he think that?
Re: OT Plane on a Treadmill [Re: sparkem] #763702 02/01/08 12:43 AM
LandRaider Offline
Because he worded the question wrong. I sure am glad this is over. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: OT Plane on a Treadmill [Re: LandRaider] #763703 02/01/08 07:46 AM
87Toy4x4 Offline
82 pages of posts..in less than two days. link
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6530 MB (Peak: 0.7597 MB) Data Comp: Off Server Time: 2026-06-07 06:08:58 UTC
