electronic 4wd not working, tranny leaking into transfercase #763721 11/08/06 03:07 PM
bugeyestp4x4 Offline OP
94 Bronco 5.0 auto.1st.. power is getting to the 4x4 switch on dash, no power coming out of it, lights are not coming on at all.. i replaced the switch having still the same symptoms. Now i believe it is the transfer case control module located behind fr kick panel. Am i correct, or should i look for somthingelse? second.. trannny fluid leaking into transfercase, note tranny is overfilled(just bought this trk) is the seal bad or is it because fluid level is to high,will lowering the level in tranny stop this problem or is the seal bad.. thx <img src="/forums/images/graemlins/notooth.gif" alt="" /> [color:"blue"] [/color] [color:"blue"] [/color]
Re: electronic 4wd not working, tranny leaking into transfercase [Re: bugeyestp4x4] #763722 11/09/06 01:10 PM
rangermaniac Offline
Well try lowering the fluid level in the tranny first but my ranger probably has the same 4WD setup it is a 1991 when you put it into 4WD the computer that controls it should click if it doesn't than that is what is bad if not then your motor is just dirty you have to take the little 4WD motor off and clean the brushes and the inside magnets with fine steel wool and contact cleaner and lube the bearings with some dry graphite spray and some kind of good oil that wont get too thick in the winter it will wok fine after that and it is pretty easy but when you take the motor off there are like 3 wires that need to be cut and soldered back on don't cut all of them let me know how it goes
Re: electronic 4wd not working, tranny leaking into transfercase [Re: rangermaniac] #763723 11/10/06 03:18 AM
Cool! thanks for the reply.. There is not any clicking noise coming from the transfercase cpu... I found a couple in nearby salvage yards. I am getting my fluids to propper level and will keep a close eye on them... <img src="/forums/images/graemlins/cheers.gif" alt="" />
Thanks for the input I will keep u posted
Sirius 101. FTE
PHP: 7.4.33 Page Time: 7.685s Queries: 15 (0.005s) Memory: 0.5930 MB (Peak: 0.6466 MB) Data Comp: Off Server Time: 2026-11-15 08:32:12 UTC
