Can you identify this part??? #763737 11/08/06 05:19 PM
Rauch_Off_Road Offline OP
(aka suprathepeg, aka Sean)
Re: Can you identify this part??? [Re: Rauch_Off_Road] #763738 11/08/06 05:45 PM
stock87 Offline
Vacuum switching valve of some sort. What's the manifold off of?
My Truck: 1987 XtraCab DLX 22R 4WD 5 Speed Manual
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." -Jeremy Clarkson
Re: Can you identify this part??? [Re: Rauch_Off_Road] #763739 11/08/06 06:55 PM
Adam F Offline
lol...I busted off the top fitting on mine...it went to the canister thing on the passenger side near the firewall....the other fitting when to a vaccum port on the manifold I beleive.
3.0 v6 right?
97 4R, stock, daily driver
Re: Can you identify this part??? [Re: Adam F] #763740 11/08/06 07:23 PM
Yep 3.0. Now what does it do? What would happen if it were hooked up backwards?
Re: Can you identify this part??? [Re: Rauch_Off_Road] #763741 11/08/06 07:51 PM
4Crawler Offline
If it connects to the charcoal cannister, that is what sucks the gas fumes out when the engine is running. A 2-port VSV can be hooked up either way, it is just an open or closed valve.
Re: Can you identify this part??? [Re: 4Crawler] #763742 11/08/06 08:19 PM
So if it were hooked up wrong would it effect idle?
Re: Can you identify this part??? [Re: Rauch_Off_Road] #763743 11/08/06 08:21 PM
4Crawler Offline
Probably not, but one way to find out is to swap the hoses and see if it makes any difference.
Re: Can you identify this part??? [Re: 4Crawler] #763744 11/09/06 12:08 AM
U
USMCTRD Offline
If it was only that easy. Its in the back of the engine in a hard to reach spot. I broke one of the tabs off when I was rebuilding the engine. I just took one from the junkyard that looked similar.
88 V6 4Runner, 2" 4Crawler body lift, 2" suspension, 32x11.50 Pro Comps
Re: Can you identify this part??? [Re: USMCTRD] #763745 11/09/06 12:30 AM
willzrunna96 Offline
if i remember correctly someone posted a thread to repair those using a copper piper and some plastic weld
Re: Can you identify this part??? [Re: willzrunna96] #763746 11/09/06 01:40 AM
Stevie Offline
I broke a pipe off once (once, so far), and repaired it with JB Weld on it's exterior. This bi-metal vacume switching valve (BVSV) opens or closes with or without heat. My 2 cents <img src="/forums/images/graemlins/drunk.gif" alt="" />.
'80 4X4 Longbed
PHP: 7.4.33 Page Time: 1.049s Queries: 16 (0.004s) Memory: 0.6418 MB (Peak: 0.7612 MB) Data Comp: Off Server Time: 2026-06-20 04:28:08 UTC
