rebuild of a 86 4runner 22re motor
#763800
11/08/06 09:43 PM
so i started my rebuild the other day and so far everything is not going to plan. when i was unhooking most of my electrical connectors they broke due to the fact they are plastic and about as brittle as a eggshell.so i dont know what to do to for when i go to assemble everything again. i am thinking maybe some electrical tape. second i finally go my engine out of the truck with a little persuasion from a hammer and a 2x4 and when i pulled the oil pan there was about a hand full of little black plastic chunks sitting int he bottom of my oil pan. I have no idea what it is but if any of u out there do please let me know. thanx for your time and input
Re: rebuild of a 86 4runner 22re motor
[Re: veach]
#763801
11/08/06 09:51 PM
Plastic is the timing chain guides, or what is left of them. On the connectors, were you releasing the metal spring clips prior to pulling them?
[Re: 4Crawler]
#763802
11/08/06 09:55 PM
yes i am releasing the metal clips but they are just breaking as i pull them apart and as for the timing chain guides they are completely intack i pulled the timing cover today and they where still there
[Re: veach]
#763803
11/08/06 10:26 PM
yes i am releasing the metal clips but they are just breaking as i pull them apart and as for the timing chain guides they are completely intack i pulled the timing cover today and they where still there the previous owner probaly is to blame
91 pickup 5.29's US GEAR.35x 12.50 trxus m/t.5 speed swap- SOLD! 96 4Runna limited-toytec/OME lift,diff drop Nitto 285/75/16 Elocked=butter 07 FJ cruiser 3" DR coilovers 285/75/16 nitto TG. allpro sliders
[Re: willzrunna96]
#763804
11/08/06 11:07 PM
the previous owner probaly is to blame X2 Those pieces float around and get stuck at the oil sump, blocking oil delivery throughout the engine. Probably why you are doing a re-build. A touch of gasket sealer on you connections, away from the copper electrical should keep them connected.
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6063 MB (Peak: 0.6710 MB) Data Comp: Off Server Time: 2026-07-16 19:10:53 UTCValid HTML 5 and Valid CSS
