exhuast sealant? #764259 11/10/06 01:14 PM
1
1986xtracab Offline OP
does anyone here use any sort of exhaust sealant when putting together exhausts(like around gaskets) I saw a kid at work using something that looked like black rtv, i think it was called walkers acousta seal, but im not positive on the name.
1986 xtra-cab 22re
stock everything
1991 bed
Re: exhuast sealant? [Re: 1986xtracab] #764260 11/10/06 03:21 PM
I have been told no sealant is used on the anifold nor exhaust
Re: exhuast sealant? [Re: 1986xtracab] #764261 11/10/06 04:57 PM
4Crawler Offline
I'll use the orange Hi-Temp RTV sealant on exhaust gaskets downstream of the O2 sensor. Put on a thin coat and let it set for 30 minutes or so then assemble. I don't use any on the exhaust header/manifold gasket.
Re: exhuast sealant? [Re: 4Crawler] #764262 11/10/06 05:49 PM
A
allochris Offline
What if i need some sealant to go btwn downpipe & manifold? The gasket itself is not sealing. Is any high-temp sealant up to the task?
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: exhuast sealant? [Re: allochris] #764263 11/11/06 12:10 AM
1
I purchased a tube of the walkers acoutsi seal today and it worked great. i think it was 7.00 for the tube at NAPA.
1986 xtra-cab 22re
stock everything
1991 bed
Re: exhuast sealant? [Re: 1986xtracab] #764264 11/11/06 01:06 AM
dogtoy Offline
Copper coat. Isn't that supposed to work best on exhaust type applications? The spray on stuff I heard works best. Spray on one coat, let it get tacky, spray on 1 more...let it get tacky, then put in place. I talked to a guy once who said this works well.
2014 FJ
Re: exhuast sealant? [Re: allochris] #764265 11/11/06 05:23 AM
R. Carver Offline
If the gasket's not sealing between the exhaust manifold and downpipe it could be a couple of things- check to be sure the surface that the gaskets (2 on my truck)mate to are smooth. When you tighten it up, go around and tighten a little at a time. That's what eventually worked for me <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: exhuast sealant? [Re: R. Carver] #764266 11/11/06 06:45 AM
A
allochris Offline
oh, i tried so many times....not even 2 brand new gasket rings...it's just not sealing at the rear(posterior) end of the flange from strange reason. (& that my stud is now cut helps too! <img src="/forums/images/graemlins/rolleyes.gif" alt="" />)
Re: exhuast sealant? [Re: allochris] #764267 11/11/06 03:50 PM
Stevie Offline
Perhaps somethings cracked! It's a tough place to do a close inspect. Removal is a pain, I know, but if you want to do it right..... <img src="/forums/images/graemlins/mrt.gif" alt="" />
Two gaskets & sealer just tells me something else is wrong here.
'80 4X4 Longbed
Re: exhuast sealant? [Re: Stevie] #764268 11/11/06 08:21 PM
A
allochris Offline
Nothing's crack, it's the mating gap btwn manifold & downpipe. My suspition is that the dp flange wrapped a little or something during welding when my friend modified my downpipe 2 yrs ago... I remember putting in new gasket donut on each pipe & i can still feel the pulsation of the gas blowing out of the gap...
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6362 MB (Peak: 0.7590 MB) Data Comp: Off Server Time: 2026-11-13 13:11:07 UTC
