What should I pack my oil pump with? #764590 11/11/06 10:04 PM
What type of grease should I pack a new oil pump with? White Lithium? Valvoline Syn Power synthetic grease? Bacon grease?
thanks,
dean
Re: What should I pack my oil pump with? #764591 11/11/06 11:52 PM
bigStinger Offline
Dean,
engnbldr and those that know there stuff have directed me to to use petroleum jelly (vaseline). The guy at the parts counter at Miller Toyota said that was hooey. I would go with EB's advice.
For Sale or Trade
33" AT Winston Wheelers. Nearly New.
all stock except for 4.88s...
Re: What should I pack my oil pump with? #764592 11/12/06 12:24 AM
VanillaTHUNDA Offline
I like the bacon grease option.
Re: What should I pack my oil pump with? [Re: VanillaTHUNDA] #764593 11/12/06 12:42 AM
The consensus here is that it is not necessary. once the engine starts it will prime it self. In my case we have flow just not much.
Re: What should I pack my oil pump with? #764594 11/12/06 12:52 AM
dcg9381 Offline
I disagree with the consensus and I've built a few motors.
I've regularly seen them refuse to prime on a complete rebuild (vatted, machined, properly cleaned). Pulling the plugs and turning them over will generate more than 250 RPM. IF they're not priming at 250 RPM, you don't want to run them dry at idle speed or above.
I pack them with grease, but that's what I've got available.
22REturbo.net
1988 4Runner
Re: What should I pack my oil pump with? [Re: dcg9381] #764595 11/12/06 02:16 AM
kyle-22r Offline
the way i see it, with how much assembly lube i use on the engines that i build, it could run quite a while without oil before causing damage. all the 22Rs i've put together cranked and cranked with no plugs and i could never get the light to go out, but as soon as i put the plugs in and got it to pop, it would go out. this is with the oil pump primed as well.
just about the same thing happens when it sits as well, especially if you use a lesser quality filter. assembly lube is stickier than motor oil, so it can't be too much worse than a regular dry start.
'91 4x4 shortbed
22R-E, W56, the dd!
Re: What should I pack my oil pump with? [Re: kyle-22r] #764596 11/12/06 04:40 PM
O
ovrrdrive Offline
Vaseline. <img src="/forums/images/graemlins/wink.gif" alt="" />
Always have always will.
Impellers, relief valve, and flow channels? #764597 11/12/06 09:15 PM
And I pack the gears only? Or do I also pack the relief valve and channels?
Re: Impellers, relief valve, and flow channels? #764598 11/12/06 09:20 PM
Smoke Offline
I prefer filling the entire chamber but not sure it's necessary!!
94 P/U Ex-Cab 3.0 Automatic 4X4
Re: Impellers, relief valve, and flow channels? [Re: Smoke] #764599 11/12/06 09:40 PM
As I recall (I'm at Home Depot fetching the Vasaline) there are three, what could be called, chambers: One holds the drive gear and driven gear (impellers), one holds the pressure relief valve, and a third is a crescent about 2 1/2" long and less than 1/8" wide with a small hole either in it or just below it, what I am calling flow chambers.
Is all this packed? Or will it hurt to pack them regardless. I'm just afrid of clogging the non-moving channels with the vsaline.
PHP: 7.4.33 Page Time: 0.021s Queries: 16 (0.016s) Memory: 0.6282 MB (Peak: 0.7336 MB) Data Comp: Off Server Time: 2026-11-11 20:10:53 UTC
