Page 2 of 3 1 2 3
Re: truck stalled....no spark [Re: irish_ROCKS] #764954 11/14/06 03:58 AM
kewlynx Offline
If it's like the 22Rxx, the module lives next to the coil. You can also take the part number and call it in to verify.
BTW, did you check your fuses? Might back up a sec if you haven't.
**ubi apis- ibi salus**
Re: truck stalled....no spark [Re: kewlynx] #764955 11/14/06 05:34 AM
I
irish_ROCKS Offline OP
ahhh duh thanks....ummm i did check already though wouldnt be a bad idea to jus recheck in the mornin thanks any idea how to test the ignition control module??
irish kicks ASS!!!!! ;-p
Re: truck stalled....no spark [Re: irish_ROCKS] #764956 11/14/06 05:48 PM
dcg9381 Offline
There may be some tests in the FSM for the igniter.
You might want to start with the distributor, it's unlikely that it failed, but it's a good thing to test. Just check it for continuity when it's turning over.
Distributor -> Ignitor -> Ecu -> Ignitor -> coil
The only way I've been able to test ignitor output into (and out of) the ECU is with an oscilliscope, which is beyond the capabilities of most shops.... Maybe there is something in the FSM that's less technical.
22REturbo.net
1988 4Runner
Re: truck stalled....no spark [Re: dcg9381] #764957 11/14/06 06:11 PM
krb90 Offline
Have you ruled out the coil?
Mine did the same thing......died suddenly while driving down the highway at 60mph. It turned out to be only the coil. No problems since.
Re: truck stalled....no spark [Re: krb90] #764958 11/14/06 08:24 PM
I
i got a multi meter on the coil and the reading was all over the map...one test the spec was like .3 and i got 0.0 or.1 .......the other test was supposed to be between 9-13....it slowly counted up to 20 but was never really stable(digital multimeter)..i know next to nothing bout ignition.....if the reading doesnt match the specs in haynes or the fsm then the coils bad.....ummmm if i have a reading like that isnt that a problem with the multimeter tho?? my mechanic buddy says the consensus at his shop is i bumped something loose...y'all frm texas should have an idea what going fast thru a dip on a lil county road is like <img src="/forums/images/graemlins/notooth.gif" alt="" />..........IF so any ideas on what else to check........i dont have spark at the coil soooo
Re: truck stalled....no spark [Re: irish_ROCKS] #764959 11/14/06 08:33 PM
dogtoy Offline
Maybe a ground wire came loose. I would definately check most of the wiring paying special attention to the ground points.
2014 FJ
Re: truck stalled....no spark [Re: dogtoy] #764960 11/15/06 06:18 AM
I
thanks alot y'all.....my mechanic buddys are all pretty sure something came loose.........i was busy today but....tomorrow i'll go over it an hopefully find and fix the problem!!!! and be back on my way to mexico <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: truck stalled....no spark [Re: irish_ROCKS] #764961 11/15/06 09:17 PM
I
tested the harness that powers the coil.....have power there soo rules out the wiring i guess.......no spark at the coil....ohm meter reads all over the map when i test the coil.....idk whats with that........guess now i jus gotta figure out if its the coil or ignitor.....
Re: truck stalled....no spark [Re: irish_ROCKS] #764962 11/15/06 09:49 PM
dcg9381 Offline
You should have power to the coil. The coil gets grounded to fire it... I *think* you can ground it yourself (very, very quickly) to verify that it will fire.
Here's an overview of the igition system:
http://lakebox.dnsalias.com/photos/1988%204runner/megasquirt/med/toyotaVAST.jpg
22REturbo.net
1988 4Runner
Re: truck stalled....no spark [Re: dogtoy] #764963 11/16/06 10:49 PM
I
checked the ground wires....went over the wiring.....everything seems ok....well a wire to the wiper motor had rubbed thru but...nothing relating to ignition
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6414 MB (Peak: 0.7490 MB) Data Comp: Off Server Time: 2026-05-29 16:24:53 UTC
