Re: truck stalled....no spark
[Re: irish_ROCKS]
#764964
11/20/06 08:44 PM
checked the ground back thru the harness ...turned out ok.........pulled the grounds to the body off an smeared dielectric grease on em n tightened em all back down......power to the module and coil........no spark...now i dont know much about ohms but my mechanic buddy says by the readings i was gettin the coil was fine.........idk im still wondering about the coil...soo guess its the coil or module (ignitor /ignition control module are the same right?)..........anybody ever have a module go???talkin 2 a mechanic in town an he said he reallly couldnt do more n i was...hed jus start replacing stuff........idk ....it died right after some gawdawful bumping....soooo i suspect the coil....but supposedly it tests <img src="/forums/images/graemlins/frown.gif" alt="" /> ok any thoughts???????
irish kicks ASS!!!!! ;-p
[Re: irish_ROCKS]
#764965
11/21/06 12:55 AM
ok the same thing happend to my truck a little wile back. just pull off the wire that goes to the dis.cap from the coial, and put about 1-2 mm away from something metel. then have a buddy turn over your engine. if there is no spark, tell your buddy to turn over your motor and then turn back the key really fast do it a couple of times. if the coil/ power pack is gone then u may get one spark if u turn back the key fast enough. if you do then al u need is a new coial/ power pack/ wel mine is built into one i'm not shure about yours. but try this it prb. will work. steve
#764966
11/22/06 12:41 AM
replaced the ignition coil ....not it ........mechanic i took it too says hed do same as me.....an toyotas are hard to trouble shoot an hed replace the module as one o the first things............opinions......the computers on these trucks....if i found a mechanic with a computer to read codes would that give u specific info or more like the ignition doesnt work DUh??i cant think of anything besides the ignition module......other then maybe i overlooked something in the wiring or grounds...i dont see how tho cuz i checked n rechecked n rechecked lol any ideas or suggestions would be appreciated thanks y'all
[Re: irish_ROCKS]
#764967
11/23/06 06:09 AM
ok blah blah bout the codes figured that out <img src="/forums/images/graemlins/zombie.gif" alt="" /> sooo today i found out o'reillys parts stores have these borg warner machines that'll test the ignition module for free ....sooo im all happpy......drive a goood 50miles and weeeelllll seeeee they dont have an end that'll work with MY module........this 5 prong(idk wat else to call it) setup isn't as common i'm told!!!!!!!!!! <img src="/forums/images/graemlins/barf.gif" alt="" /> HA its kinda funny how im jinxed with this thing.......theres a awesome landcruiser place in austin ...bout 100 miles away BUT their numbers disconnected,an their sites down <img src="/forums/images/graemlins/lol.gif" alt="" /> ........ssoooo i'll eat turkey an fri morning call another mechanic to see bout testing this thingi.....then if i order the module fri before 5 i'll be outta $245,an have it saturday an HOPEFULLY be up and running lol.......thanks y'all for all the advice n opinions an all that lol....i now know waaay more bout my ignition then i ever wanted to <img src="/forums/images/graemlins/lol.gif" alt="" /> JK
[Re: irish_ROCKS]
#764968
11/25/06 07:46 PM
I NEED IDEAS <img src="/forums/images/graemlins/confused.gif" alt="" /> ....i have a new ignition module and ignitor/ignition control module .....and STILLL NOOO SPARK !!!!!!!!!! <img src="/forums/images/graemlins/confused.gif" alt="" /> <img src="/forums/images/graemlins/confused.gif" alt="" /> coil:has power and the ground thru the harness checks out module:ground thru harness checks out,one wire has power....stilll have 3 more wires.....are they "returns"??? ..........if i have power and a new module and coil.......where do i go back to now??????the main computer???how would you check that???????insult to injury most of the mechanics around here dunno anything about toyotas........ANY IDEAS WOULD BE APPRECIATED lol im stuck thanks y'all
[Re: irish_ROCKS]
#764969
12/08/06 09:16 PM
junkyard distributor installed.....stilll no spark........im stuck........ecu is next i guess?????? is there anything i might be overlooking????? guess ima give using the jumper wires to check codes a shot........tho the mechanic in town said the computer clears itself if the batterys been disconnected........an since i was workin on the ignition it has been .........OOPS ....... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6183 MB (Peak: 0.7054 MB) Data Comp: Off Server Time: 2026-06-21 19:01:21 UTCValid HTML 5 and Valid CSS
