alternator welder #765042 11/13/06 06:59 PM
rvdjr Offline OP
can anybody give me the names of the manufacturers of alternator welders? the only one i can find is "premier".
Re: alternator welder [Re: rvdjr] #765043 11/13/06 07:11 PM
BobRowe Offline
The only one I've seen installed on trail vehicles is the Premier Power Welder. There are probably other brands, but Premier is undoubtedly the most popular. You might try various descriptions in Google.
Re: alternator welder [Re: BobRowe] #765044 11/14/06 04:36 PM
rvdjr Offline OP
i looked for one of these a couple of years ago,but didnt buy one. back then i found 4 or 5 different makers and a wide price range. but now i can only find the one and its dang expensive!
Re: alternator welder [Re: rvdjr] #765045 11/14/06 07:07 PM
kc77cj7 Offline
I think lincoln males one called Linc-arc or Linkarc.
77 CJ-7 258 31" MTR's - now...
360, TF727, DANA 300, DANA 44's all sitting in the garage just waiting...
Re: alternator welder [Re: kc77cj7] #765046 11/16/06 10:52 PM
Mudlover27 Offline
what about installing a large inverter, and running a 110 welder off that,, I am in the middle or working out power issues right now with that exact setup
ML
98 wrangler 2.5l 3 inch rustys, 2 inch body, 33X12.5 MTR's DETROIT LOCKER, 4.88 gears, moser axles, Dana 44 (rubicon housing)
Re: alternator welder [Re: Mudlover27] #765047 11/17/06 05:31 PM
superdawg Offline
The inverter to handle that load would cost twice what a premier power welder costs, not to mention it would be huge and a ppw can burn 1/2 steel with no trouble, try that with a 110 welder. If you want a onboard welder because it would be "nice" to have one along "in case" just carry (sealed well) some welding rod of different sizes and grades.
Two batteries and a couple sets of jumper cables, this will get you out of most pickles.
If you see yourself trail welding a lot...get a PPW.
SD
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6066 MB (Peak: 0.6755 MB) Data Comp: Off Server Time: 2026-06-17 21:29:42 UTC
