Re: Bolt on hitch question [Re: Robb] #765058 11/21/06 11:48 PM
KB2IAW Offline
yup i bought mine at the trackter supply store ,bolts right up with the original montero bolts...the bolts that came with mine were different and had nuts with them /they were of a different thread pattern ...but be careful when you try to un hitch you may not have clearenc because of the rear spare tire ... I have to open the rear door the remove the trailer tonge..not much of a problem .
1994 montero SR 3.5 v6
City Of Hills Oneonta N.Y. FREEDOM HAS A TASTE,AND FOR THOSE THAT HAVE FOUGHT FOR IT, THE TASTE IS SO SWEET , THE PROTECTED WILL NEVER KNOW .
VENI VEDI DECI <oneontasportsmenclub.net>
Re: Bolt on hitch question [Re: Robb] #765059 11/22/06 02:34 AM
JAVYPRO Offline
I saw a montero in the junkyard with a hitch like this
Is that a standard bolt pattern on the back of the Montero that accepts a hitch like this?
How much they run for?
88 red Montero with the Dakar Special Edition decals, 438,000 miles (As of 7/23/2012) some occational blue puffing but still strong and counting!!! I am going ppsshhh (turbo), Stay tuned =) ...
Re: Bolt on hitch question [Re: JAVYPRO] #765060 11/22/06 03:52 AM
Robb Offline OP
about 70-80 bucks new.
-Robb
1992 Montero (pics)
www.HondaForeman.com
Re: Bolt on hitch question [Re: Robb] #765061 11/23/06 08:00 PM
grass13 Offline
make sure you chase the threads before you try to bolt it up. than you can send the tap to me, so i can do mine <img src="/forums/images/graemlins/smile.gif" alt="" />.
Re: Bolt on hitch question [Re: grass13] #765062 11/23/06 08:24 PM
sparkem Offline
My threads are all rusted up and the bolts are very hard to put in or out.. I am goint to drill the holes out and knock off the nuts on the back and put in some 1/2in grade 8 bolts and nuts.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.003s) Memory: 0.6125 MB (Peak: 0.6767 MB) Data Comp: Off Server Time: 2026-06-24 14:34:31 UTC
