BackFire in ALL gears.
#765157
11/14/06 01:25 AM
Ok, this may sound dumb, but I have a really bad Back Fire in all gears wether it's cold or up to temp. I have checked the Wires, they are with in the Resistence it needs, Coil, its where it needs to be, Cap and Rotor nothing odd there. checked the timing, ok. So, Im down to spark plugs, Could the Gap already need to be checked?? I know your supposed to Gap check them before you put them in, But I was in a hurry when I did the ReBuild and just put them in. Now my Chiltons or Haynes isnt specifying a Proper Gap. BTW: 89' 2.6L 4ZE1. and its really loud when it does it only while shifting gears. If anyone has pointers and gap Spec that would be Great. Thanks.
89'Isuzu Trooper LS 5 spd 2.6L 31" Big O X/T's 15x8 Eagle 058's K&N Filter w/ Air Box Mod 2.25" DynoMax SuperTurbo PolyUrathane/Indy4X Bushings Suspension/ FrontEnd Tech/Hunter Certified Alignment Tech.
Re: BackFire in ALL gears.
[Re: 88SuperTrooper]
#765158
11/14/06 02:16 AM
Sure it's not an exhaust leak?
[Re: Fujisawa_Rob]
#765159
11/14/06 03:22 AM
Im sure it's the Plugs, but I cannot find the Gap at all to eliminate the plugs from this, We checked for an exhaust leak, but that wasnt very though since its comming through the muffler.
#765160
11/14/06 04:10 AM
1MM PLUG GAP .040 IN THOUSANDS JERRY
#765161
11/14/06 10:16 PM
I'd recheck the timing and check the valve clearance again. Passing exhaust valves are a classic for backfire. Cat converters don't last long with detonation and passing valves burn up so don't delay. And don't be in a hurry or you'll be doing your re-build again...soon... It took me two head rebuilds to figure out that ...
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
[Re: RT1]
#765162
11/15/06 01:51 AM
There is no Cat... We put a Piece of test pipe in to see what Difference it would make with those Brick Style cats mine had. So far its Great, High Flow Cat is up next. As far as Valve Lash Goes, We set them at every 5000 miles to keep on top of it ( its been done 3 times with in 3000 Miles from noise in the Valve train). I dont wanna buy another head for this thing for a long time. Ill check the timing again to make sure. Thanks Jerry Ill try that and see what that does. Im using Octane Booster on Mid grade for fuel mileage reasons, Its done it before this but its getting a little worse this time around.
#765163
11/15/06 03:46 AM
Isuzu Moderator
Octane does not equal mileage. You are wasting your money.
Michael
[Re: mlclark]
#765164
11/16/06 12:28 AM
You Sure? Im getting 21 to 24 MPG Average. On Reg. Im getting 16 to 19 Average. Im pretty sure its helping. But you may also be right, maybe the Mid Grade itself it just doing it just fine, and Im wasting money. Ill run a couple of tanks to see. Im letting the Trooper sit for a bit so I can gap the plugs and see if it helps any. Its running awsome though.( these little 2.6's run really really well- before it was running on 3 due to a burnt exhaust Valve on #3 Cyl.) Had to pull a car out this morning due to them sliding into a ditch after screwing around. Low Range Baby!
#765165
11/21/06 06:59 PM
If mine hadn't dropped a valve guide, I would have never guessed I was running on 3 cylinders. The #2 exhaust valve was burnt with about a 1/4" side cut out. And yes it backfired in every gear..
86' Trooper, 2.3, 31" wild countrys, pro comp shocks.
[Re: desertbenny]
#765166
11/22/06 03:15 AM
Well Due to mis Gapped plugs, and and a vacuum hose that had split that was what was causing it to back fire.. got it fixed after I had seen the hose and it runs great. again. <img src="/forums/images/graemlins/scared.gif" alt="" />
