Page 1 of 4 1 2 3 4
Crossover eliminator for 3.0. #765358 11/14/06 05:22 PM
Rauch_Off_Road Offline OP
I'm gonna have one fabbed up for my build and am wondering what kind of interest there is out there for more. I'm not looking to get rich or anything of these just wondering who would be interested in getting one.
This would basicly be a Y-pipe and a block off plate for the stock manifolds. 2" to 2.25 with maybe an o2 bung. I still have to work out how I'm gonna build it but the design it pretty simple and it will get rid on the stock crossover.
I don't know how much power this will free up but it will deffinately free up some. On the 3vzfe its usually worth ~10hp with headers being worth less then 5. If enough people are interested I'll do mine and take it to the dyno to see what its worth.
Initially I'm thinking the cost will be $180-$200USD with true mandrel bends and a flex section to make installation easier. Not the cheepest I know but bolt on, cheeper then headers. and gets rid of the crossover gasses coming into the manifold and onto cyl 6. The more I can have made the cheeper each one gets I'd like to get it down to $150 if I can.
let me know if there is interest and I'll put together a group buy.
(aka suprathepeg, aka Sean)
Re: Crossover eliminator for 3.0. [Re: Rauch_Off_Road] #765359 11/14/06 08:07 PM
OOP'S Offline
Sounds good, where to you plan on running it? I may be interested!!!!
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: Crossover eliminator for 3.0. [Re: OOP'S] #765360 11/14/06 08:30 PM
dogtoy Offline
I have headers now but before that would've definately interested me. May want to include new bolts if you venture it, I like many before me, ended up cutting more than unbolting. Sourcing that kind of stuff becomes a pain and having it all there would be even more attractive. This way when you finally get that wretched crossover and bolts outta there just bolt on and go. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2014 FJ
Re: Crossover eliminator for 3.0. [Re: dogtoy] #765361 11/14/06 11:45 PM
K I'll let you guys know how it goes.
Re: Crossover eliminator for 3.0. [Re: Rauch_Off_Road] #765362 11/15/06 02:06 AM
Snowtoy Offline
You might consider designing the x-over pipe to go between the tranny and the front driveline, this way you could keep the O2 sensor in the stock place, and out of the way. I modified the Downey kit to run it this way, I didn't like how they have it designed to go below the driveline.
Re: Crossover eliminator for 3.0. [Re: Rauch_Off_Road] #765363 11/15/06 04:05 AM
Kutter Offline
Where did you get the 10 hp gain figure from?
1995 4Runner Limited V6 3.4 Liter 5 Speed 4x4
1995 4Runner V6 Auto 2WD
Re: Crossover eliminator for 3.0. [Re: Kutter] #765364 11/15/06 04:49 AM
I wouldn't mind doing some sort of crossover elimination with a better flowing y-pipe setup but I would want to keep the O2 sensor in the same location and the cat in the same location.
Re: Crossover eliminator for 3.0. [Re: Kutter] #765365 11/15/06 08:45 PM
This is from some of the Camry/Lexus es300 guys. Not exactly the same engine I understand but same exhaust setup. To be honest I'm expecting I'll see pretty significant results on mine but that's more to do with what I've done to my engine.
Re: Crossover eliminator for 3.0. [Re: Rauch_Off_Road] #765366 11/15/06 11:14 PM
bkg Offline
Even if it's worth 0 hp, it will be worth getting that huge heat-sink away from that cylinder...
Brian K. Gallus
Re: Crossover eliminator for 3.0. [Re: Rauch_Off_Road] #765367 11/16/06 02:07 AM
Kutter Offline
Where you thinking you would use the factory flanges at the manifolds and cat to weld the new pipes to?
Page 1 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6350 MB (Peak: 0.7582 MB) Data Comp: Off Server Time: 2026-06-16 06:52:11 UTC
