squeek from double cardan joint---help! #765390 11/14/06 06:40 PM
E
EricsTJ Offline OP
Guys---97 Wrangler TJ. The front driveshaft double cardan u-joint has developed a loud squeek...I have removed it, and cleaned the "cup and rubber seal" in the middle of the 2 u-joints---The squeek goes away for a couple of weeks, or until it gets wet or muddy..
I have used a variety of cleaners and different lubricants including white lithium, silicone, and even WD-40.
There is no play in the u-joints, and those move smoothly---just that "cup" in the center...
Any help would be appreciated---Can the double cardan be rebuilt, or do I have to replace the whole driveshaft?
It is off the vehicle now because it gets so loud! <img src="/forums/images/graemlins/barf.gif" alt="" />
Re: squeek from double cardan joint---help! [Re: EricsTJ] #765391 11/14/06 06:47 PM
superdawg Offline
Any good drive shaft shop can rebuild it, it takes some special tools and know how on a CV.
SD
Re: squeek from double cardan joint---help! [Re: EricsTJ] #765392 11/16/06 03:18 AM
NCBBA2358 Offline
Never use WD40 as any kind of lube that you expect to last more than a few seconds. WD in WD40 stands for "Water Displacement" and isn't designed as a lube. Grease makes for a great lube.... Just figgerd I'd mention that....
91 Jeep Wrangler YJ, carpet, tires, trailer hitch. yea....
Re: squeek from double cardan joint---help! [Re: NCBBA2358] #765393 11/21/06 08:57 PM
E
EricsTJ Offline OP
Guys---found an answer to my problem----it was my exact problem---thought I would share it with others with the same noise:
www.stu-offroad.com/axle/driveshaft/driveshaft-5.htm
<img src="/forums/images/graemlins/lol.gif" alt="" />
1997 Wrangler TJ 5 speed, 2.5 L. Mostly stock except for 31x10.50's on Black Rockcrawler Rims.
1998 Wrangler TJ 5speed, 4.0L. Rusty's 3.5 " lift,33"BFG,4.10 gears,Novak transfer case shifter
Re: squeek from double cardan joint---help! [Re: EricsTJ] #765394 11/22/06 06:23 AM
BobRowe Offline
Excellent sosurce of information! Thanks for sharing it with us.
PHP: 7.4.33 Page Time: 1.761s Queries: 15 (0.007s) Memory: 0.6047 MB (Peak: 0.6693 MB) Data Comp: Off Server Time: 2026-11-14 14:35:46 UTC
