22re Stalling
#765600
11/16/06 01:28 AM
My engine with and auto tranny stalls when i put it into reverse or drive. if it doesn't stalls it idles really rough. but if i step on the gas or drive it, it stops. any idea what my problem is?
Thomas
94 Toyota Pickup 22R-E EB's Street RV Head with 268* Cam
Re: 22re Stalling
[Re: casper3t]
#765601
11/16/06 03:42 AM
Check the idle speed. Maybe it is set too low. Jeff
It's all good! 83 Shortbed stepside lots of mods 82 Shortbed fully restored 85 Shortbed daily driver 88 4-runner-Wife's daily driver
Re: 22re Stalling
[Re: Jeffstoyo]
#765602
11/16/06 03:47 AM
I had a mazda that would do that, and sometimes just die for no reason. I took the ignition switch out, cleaned it and it never happened again. Not too sure otherwise, I'm anxious to see the cause! <img src="/forums/images/graemlins/scared.gif" alt="" />
Re: 22re Stalling
[Re: Jeffstoyo]
#765603
11/16/06 04:44 AM
U might check with a transmission shop and see if your truck has a torque converter look up solenoid. If so then that might be your problem. I see this in the American built cars all the time.
Re: 22re Stalling
[Re: EzCruiser]
#765604
11/16/06 05:50 AM
What does it idle at? If you turn on the AC what does it idle at?
22REturbo.net 1988 4Runner 22RTE core, turbocharged, megasquirted...
Re: 22re Stalling
[Re: dcg9381]
#765605
11/17/06 10:31 PM
its idling at 750 and timing is right, i didn't caught the idle when my a/c is on. i think there a vacuum leak but i can't find it. it happens when the engine is warmed up too. well if i had the a/c on and start the car, it would start but die right away.
Thomas
Re: 22re Stalling
[Re: casper3t]
#765606
11/17/06 11:31 PM
The AC should have a working VSV valve that engages fast idle when the AC gets turned on. It's a fairly common failure point - there is documentation on how to test it in the manual... Not related to your tranny engagment issue though.
I don't know much about the automatics. Does anyone know if the automatic rigs have something similiar to advance idle against the load of being put in gear?
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6177 MB (Peak: 0.6909 MB) Data Comp: Off Server Time: 2026-05-29 23:31:28 UTCValid HTML 5 and Valid CSS
