IFS Front driveshaft question
#765769
11/17/06 01:18 AM
My front driveshaft on the new truck doesn't seem to have a block off plate to stop the grease from coming out of the end of the slip joint. What is actually supposed to be there? Is it a welded in piece, or some type of pressed in plug? Any suggestions short of getting a new driveshaft, or at least the front slip joint part? See pic for where it is coming out. I can stick my finger right up inside the driveshaft, there's nothing there to stop the grease. Thanks in advance. ![[Linked Image]](http://img292.imageshack.us/img292/921/frontdriveshaftwn7.jpg)
Jeremy 88 Toyota Pickup 22RE, 31x10.5's, Warn M8000, Marlin rear bumper
Re: IFS Front driveshaft question
[Re: mudking82]
#765770
11/17/06 01:57 AM
Often a steel plug in there with a small hole. Maybe you could find a rubber stopper or a freeze plug of about the right size and shove it in there. Just make sure there is a small vent hole to let air and excess grease out.
[Re: 4Crawler]
#765771
11/19/06 12:27 AM
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.5933 MB (Peak: 0.6469 MB) Data Comp: Off Server Time: 2026-11-03 05:44:35 UTCValid HTML 5 and Valid CSS
