Re: squealing noise... advice? #765825 11/19/06 08:36 PM
half_fast Offline
spray some lubricant on your belts just to be sure its not a belt.
My bet is a throw out bearing.... but the arguement for the thrust bearing wear is convincing.
Michael J. Carsner proud driver of "Aint Pretty"
37 boggers, 571 gears, Detroit+Lock-Rights, 20R stage 1 LC Engineering head on 22R motor.
MUD!!! Its whats for dinner!!
Re: squealing noise... advice? [Re: half_fast] #765826 11/19/06 10:03 PM
Davepet Offline
It is almost certainly *not* the throw out bearing or pilot bearing. They should not be spinning under the conditions he is getting the squeal.
He only gets the noise with his foot off the pedal. The throwout bearing (& pilot bearing) only operate when the pedal is pushed in.
Dave
Re: squealing noise... advice? [Re: Davepet] #765827 11/21/06 03:24 AM
All right. I went under my truck to find out about the noise. Turns out I have been off on the location. It was under my truck, which became apparent once I was under it.
And it turns out that the little bugger making all the noise was this: [Linked Image]
Yup. The clutch release cylinder push rod/clutch release fork connection point. I sprayed lubricant on it and the noise stopped (as a test).
Now, the question I have is: should refurbish the release cylinder or buy a new one and has anyone does this before and how hard is it?
Thanks for all the replies. You guys rock.
Re: squealing noise... advice? #765828 11/21/06 03:59 AM
kewlynx Offline
New one doesn't cost that much. Read up on clutch maintenance via our 'toyota section' above in the header.
**ubi apis- ibi salus**
Re: squealing noise... advice? [Re: kewlynx] #765829 11/21/06 06:00 AM
Is there a large difference between the Advance Adaptors slave cylinder and the Coni? The price difference is $68 to $12.
here is the URL to the coni:
http://store.summitracing.com/partd...5005+4294925134+115&autoview=sku
Re: squealing noise... advice? #765830 11/21/06 08:14 AM
kewlynx Offline
Couldn't tell ya. I go OEM or with Marlin's Seems to me the one from the dealer ran about $35, but it's been awhile.
PHP: 7.4.33 Page Time: 0.015s Queries: 15 (0.011s) Memory: 0.6138 MB (Peak: 0.6802 MB) Data Comp: Off Server Time: 2026-07-15 02:24:25 UTC
