Page 2 of 3 1 2 3
Re: 15" wheels on a Gen3 [Re: icysyrup] #765991 11/18/06 11:12 PM
Alex Kogan Offline
Yep it's all stock.
08 PowerWagon (stock!)
Re: 15" wheels on a Gen3 [Re: Alex Kogan] #765992 11/18/06 11:39 PM
Seif1 Offline OP
OK, so I know I can fit 33's without any lift (thanks Alex). I think 35's are doable with a two inch lift (baring any real negative offset wheels).
My next question goes back to wheel options...
I want to get rid of those NASTY factory spider wheels from the 01 model.
I like the looks of black Rock Crawler wheels and am trying to figure out what backspacing to get.
Factory wheels are 16x7 +44 offset 5.75" BS
I want to run 8" wheels, but I'm having a hard time finding them with a ppositive offset. I think a 5-5.25" BS would be ideal...Most of what I find are 4.5 BS which is dead center of the wheel.
Thoughts?
2003 Jeep Grand Cherokee
34K
6" Long arm lift
Rock Sliders
ARB Bumper(s)
Mile Marker winch
285/75/16 Dueler AT's
ARB air locker (front)
Custom Roof Rack
Re: 15" wheels on a Gen3 [Re: Seif1] #765993 11/19/06 12:17 AM
Oyaji_Jon Offline
I think the backspacing you're looking for is way too much. 5-5.25 BS will tuck the wheels way into the wells and, if you are running a wider tire, may cause rubbing. In fact, the 4.5 with wider tire may be too much. If you can gat a 3.75 or 3.5 BS, I think that would be ideal. Not to mention the wider stance will look and feel better.
I don't think you'll find a wheel with the BS you're looking for unless you have them made...
Good Luck (from the guy who is too poor to afford a Gen 3)!
Edit: Apparently I'm talking out of my butt. After re-reading the above posts, it looks like the wider tires will fit your rig with factory BS. I guess I don't get it. Anyway, the biggest BS I've ever seen on the Steelies is 4.5. My guess is to go with those if you really like the look.
73
-Jon
KJ6GVM
As seen on Expedition with TX plates: VEGETARIAN - An old Indian word for poor hunter
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: 15" wheels on a Gen3 [Re: Oyaji_Jon] #765994 11/19/06 12:28 AM
Oyaji_Jon Offline
Here is the closest thing I could find to your criteria. They won't break the bank with free shipping, and they look just like mine <img src="/forums/images/graemlins/notooth.gif" alt="" />.
Have a look...
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: 15" wheels on a Gen3 [Re: Oyaji_Jon] #765995 11/19/06 12:46 AM
Seif1 Offline OP
Thanks!!
34K
6" Long arm lift
Rock Sliders
ARB Bumper(s)
Mile Marker winch
Custom Roof Rack
Re: 15" wheels on a Gen3 [Re: Seif1] #765996 11/19/06 01:28 AM
icysyrup Offline
When these tires wear out I am going to be putting diff rims on to get the tires sticking out the fenders some. Prob going to be working towards 6" wider on both sides total with diff rims/tires.
And just so you know....35's WONT fit without some trimming up front cause there is about 1/2 inch space with 33s. Just so you know.
03 Montero XLS, OME 2"suspension lift,Full skid plates, Extended Diff/transfer breathers. 34 LTB's, Winch w/syn rope, Locked front/rear.
Re: 15" wheels on a Gen3 [Re: Oyaji_Jon] #765997 11/19/06 02:53 AM
Alex Kogan Offline
Have a look...
Those won't work they are not going to clear the brake calipers. In fact it's pretty hard to find wheels that will. I've got some different wheels for my Gen2 none works because of caliper clearence. Also remember that Monty wheels are hub centeric and that hub center bore is only 78mm. I belive, pretty much any other, but stock offset, wheel will cause rubbing with 33"
Re: 15" wheels on a Gen3 [Re: Alex Kogan] #765998 11/19/06 03:20 AM
icysyrup Offline
Agree with what you said Alex. The tires stick out any further and there will need to be some modifications <img src="/forums/images/graemlins/wink.gif" alt="" /> done to the bumper.....its just tupperware anyways.... <img src="/forums/images/graemlins/lol.gif" alt="" />
Re: 15" wheels on a Gen3 [Re: Alex Kogan] #765999 11/19/06 05:12 AM
Oyaji_Jon Offline
Well, I tried... <img src="/forums/images/graemlins/confused.gif" alt="" />
My older truck doesn't have the same issues as yours I guess. Good luck finding what you want! <img src="/forums/images/graemlins/cheers.gif" alt="" />
73
-Jon
KJ6GVM
Grampa's Trooper
1974 FJ40
1987 FJ60
Re: 15" wheels on a Gen3 [Re: Alex Kogan] #766000 11/19/06 11:14 PM
Seif1 Offline OP
OK, I understand the old Hubcentric deal (I'm a '80's model BMW owner).
Every wheel I find on the net (including Discount) is not hubcentric. I see plenty of Mitsu's running around with 20's (gay) so I am thinking that it is not as big of a deal on the Montero?...
Click here to see the wheels I want.
Also, I'm not afraid to cut some of the "Tupperware" off...I've already removed the lower sill pieces and will have rock rails built to fit.
Thoughts?
.......Also remember that Monty wheels are hub centeric and that hub center bore is only 78mm......
Page 2 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.6416 MB (Peak: 0.7522 MB) Data Comp: Off Server Time: 2026-06-23 21:15:44 UTC
