Page 1 of 3 1 2 3
Pajero 4D56 (2500) Parts Cross-Reference List! #766216 11/19/06 05:26 AM
PHIL_ Offline OP
There's quite a few diesels posting now, and many are from Canada/US, so I thought it prudent for us to start compiling our 4D56 parts crossref's in one thread, to help each other, and any newbies that come along.
Here are a few guidelines, to keep the thread from getting cluttered and thus less useful:
-Try to refrain from chat/conversation in this thread - if you need to comment, make a separate post.
-If someone has already posted with a part number, and you have another number to add for the same part, PM me, and I'll edit/add it to their post (since your edit priveleges on your own thread expires after a short time). This will keep the part types together.
-Don't post your cross-ref number unless you have either used it, or have it on reliable info, i.e. Mitsubishi's CAPS program, etc (like the some of you, I've compiled literally HUNDREDS of part numbers, but I won't post any till I buy/try em first)
-Try to include the retailer where the part is available, if applicable.
-Turn OFF your signature PLEASE (just for this thread only)
The format we will use is:
Part name:
Part Brand and Number (retailers name)
I'll start in the next post below.
Phil <img src="/forums/images/graemlins/smile.gif" alt="" />
Oil Filters [Re: PHIL_] #766217 11/19/06 05:37 AM
PHIL_ Offline OP
Oil Filters:
-Wix 51067 (Available at NAPA, and other Wix Retailers)
-Baldwin BD28 (Union Tractor, Traction, etc, as per Torquemonster)
Re: Oil Filters [Re: PHIL_] #766218 11/29/06 11:27 PM
W
Wanker Offline
Fuel filter
Napa/Wix # 3128
Block heater
Napa # 605-3509
1991 Pajero 2.5 TDi BoUnCy seats 33s OBA & Syn bow to stern.
Pajero in spanish ='Wanker'
Rear Brake Pads [Re: Wanker] #766219 01/04/07 07:42 AM
PHIL_ Offline OP
Rear disc brake pads to fit V24/44:
"Raybestos" ceramic: PGD567C (as specc'ed for 92 Montero)
Main charging 100A Fuse [Re: PHIL_] #766220 01/07/07 07:52 AM
redbull Offline
100A Main Charging circuit Fuse
NAPA part # 782-2035
Block Heater [Re: redbull] #766221 01/07/07 05:37 PM
PHIL_ Offline OP
Frost plug type coolant/block heater:
Temro pn 3100051 (Canadian Tire)
Air Filters [Re: PHIL_] #766222 01/07/07 05:46 PM
PHIL_ Offline OP
Air Filter
K&N E2871 (Auto Parts Plus, NAPA)
auto transmission kit [Re: PHIL_] #766223 01/07/07 10:59 PM
V
vlad4d56 Offline
FT1112, Fram kit (filter and 2 gaskets) - in Lordco.
Re: Rear Brake Pads [Re: PHIL_] #766224 01/18/07 04:50 PM
Neo Offline
Front disc brake pads to fit V24(Early production):
"Raybestos" ceramic: PGD349C ( [color:"red"]as spec'd for 1991 Montero [/color] )
AutoValue Parts
***These pads are 128mm in length - measure yours first***
1991 JDM SWB Pajero TD - Sold....
1997 Dodge Ram 2500 Cummins 4x4
Headlights and front signals [Re: Neo] #766225 02/05/07 06:42 AM
redbull Offline
For converting a JDM Gen2 LWB Pajero to DOT spec Gen2 Montero headlights:
Headlights
Mitsubishi part #s: MB623253 and MB623254
**Note Pajero is H4(9003) bulb and Montero is 9004. Grab a 9004 socket (and bulbs) to splice in place of the H4 one. Also order bulb retainer ring (Mitsubishi part# MB623229) and rubber cover (Mitsubishi part# MB683963) if ordering new parts. Used parts may come with these already. You may be able to modify the Pajero rubber cover to fit, but you risk water getting into your expensive headlights!
Front Signals
Mitsubishi part #s: MB677763 and MB677764
These are amber colored single bulb signals and you will lose the Pajero's cornering lamps.
Re: Triple Diamond Logo [Re: PHIL_] #766226 04/05/07 06:05 AM
Pajerist Offline
MB619578-2
red colour plastic for grill
Front ball joints [Re: redbull] #766227 04/06/07 11:46 PM
Rooman Offline
Hi Guys,
Front right ball Joints for a '92 Pajero LWB.
Rock Auto parts: Upper right side K9753
Lower left side K9755
1991 JDM Pajero 2.5TD 4 Door
Re: Front ball joints [Re: Rooman] #766228 05/24/07 01:42 AM
torquemonster Offline
[color:"red"] Contitech Timing belt kit part #'s [/color]
Timing belt kit # - CT517K1
Balance shaft belt kit # - CT714K1
each kit comes with the belt, and spring tensioner/pulley
Re: Front ball joints [Re: torquemonster] #766229 08/09/07 05:19 AM
Jonno Offline
Front brake pads for a 91 Pajero
NAPA AE7241M
although the part number is for metalic pads it will be easy for a shop to cross reference off this number. I changed the rear pads about 6 months ago and just used the spec pads for a 92 montero.
Cheers
Re: Pajero 4D56 Parts Cross-Reference List! [Re: PHIL_] #766230 08/23/07 06:06 AM
V
VERRELLI Offline
Re: Pajero 4D56 Parts Cross-Reference List! [Re: VERRELLI] #766231 08/23/07 03:26 PM
hazy_daze Offline
Rotor Part #'s
NAPA
4885926 if equiped with single piston calipers
4886687 early GenII with dual piston calipers
4886690 later GenII no dimensional difference, other than discard specification (minimum thickness) May have something to do with ABS availability, not sure.
Caliper Part #'s
NAPA
14263069 L single piston
14263070 R " "
14264009 L dual piston
14264010 R " " These 2 #'s are also a good brake upgrade if you have the single piston's up front. They come with the brackets to direct swap, as well as the pads.
Recommended Tranny fluid is 3 diamond from the Stealer, however, I've used Valvoline Max-Life ATF with no issues.
Let me know if any more #'s are needed, I'm bored at work today *YAWN* <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Pajero 4D56 Parts Cross-Reference List! [Re: hazy_daze] #766232 08/24/07 08:05 PM
redbull Offline
No difference with front and rear?
Re: Pajero 4D56 Parts Cross-Reference List! [Re: redbull] #766233 08/24/07 09:34 PM
hazy_daze Offline
NAPA #'s
Rear rotors
4886378
Rear Calipers
14264011 Left Rear
14264012 Right Rear
Pads
CMX7447
Hope it helps <img src="/forums/images/graemlins/cheers.gif" alt="" />
BTW, these #'s are for 92 US-spec Montero's, which will be the same on ya'll's 91+ Pajero's <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Pajero 4D56 Parts Cross-Reference List! [Re: PHIL_] #766234 10/03/07 01:24 AM
PHIL_ Offline OP
In order to keep this particular thread as useful and uncluttered as possible, I would urge all to re-read the guidelines at the top, re-referenced here:
signature is on by default: please turn it off in this thread
Part name:
If everyone doesn't follow this, the thread will eventually get mired down in offshoots and questions, when the idea of it is to keep it short and simple, so if you're looking for something, you can find it quickly.
If you're looking for a number that's not here, post it as a separate question. Once you find it, and try it, post your numbers on this thread, so others can benefit. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Thanks
Phil
Pitman Arm [Re: PHIL_] #766235 11/12/07 07:29 AM
PHIL_ Offline OP
Pitman Arm
Moog K9752 (as spec'ed for LHD 92 Montero): Auto Parts Plus
Rear calipers [Re: PHIL_] #766236 11/23/07 04:45 AM
Jonno Offline
1991 Pajero LWB Rear Calipers
Fenco SLC9024
Fenco SLC9025
Timing belts [Re: Jonno] #766237 12/04/07 02:34 AM
bae146 Offline
Upper Rad hose Napa 8314 31.33
Lower rad hose Napa 8163 30.19
ôLö shaped heater hose Napa 10734 8.27
ôsö shaped heater hose. Auto value good year # 63812 13.28
Sway bar bushing Napa 265-2453 27.88 Parts not installed yet but look good
Sway bar repair kit Napa 265-1313 10.33 (end links) Parts not installed yet but look good
Timing belt Napa 250091
Balance shaft belt Napa 250092
Tensioner Napa T41050
Tensioner Napa T41049
Oil Filter Napa 1067
Fuel filter Napa 3128
Block heater Napa 605-3509
Fan belt/Alternator Napa 25-22425
AC belt Napa 25-9365
PS belt Napa 25-9447
Clutch Slave cylinder Mitsubishi MB670211 100.00
Prices are at the end where available
(edit: Doug gave us some updated numbers: PH)
rad cap [Re: bae146] #766238 12/11/07 03:52 AM
bae146 Offline
Rad cap (Moto Rad Brand) 14-1008-6 T16R About 10 bucks Auto Value
U Joints [Re: redbull] #766239 07/17/09 08:19 PM
spence121 Offline
All Montero Models (Gen 2) Rear Drive Shaft U-Joints. (Same for Pajero)
NAPA #2-0151
Federal Mogul (Precision Line U-Joints) 450PRE
Federal Mogul Precision also has front Shaft U joints for Gen 2. I think it is a 398PRE but check with retailer.
"WE ARE ALL A PRODUCT OF OUR OWN DECISIONS"
92 Mitsubishi Pajero XR 2.5 TD (SOLD and feeling lost without it)
OME Suspension
American Racing steel Wheels with
Dick Cepek FCII Tires
timing belt kit and balance shaft belt kit [Re: torquemonster] #766240 08/13/09 06:38 AM
sasquatch Offline
can't find Pajero in there catalog
where did you order? directly from continental?
Thanks
Re: Oil Filters [Re: PHIL_] #766241 11/12/09 05:44 PM
spence121 Offline
Oil Filters:
NAPA Brand filters are WIX but they say NAPA instead. Part number is 1067.
(Napa just drops the first number)
OME Suspension
Re: Oil Filters [Re: spence121] #766242 06/01/10 12:37 PM
PPG windshield for 1992+ Montero
Part#: FW711
Re: Pajero 4D56 (2500) Parts Cross-Reference List! [Re: PHIL_] #766243 07/22/10 12:31 AM
I
inh0001 Offline
1990 Rear brake shoes
N.A.P.A... AE524
Re: Oil Filters [Re: Wanker] #766244 01/12/11 04:14 PM
metalfaced Offline
double checked the WIX filter I'm using right now, its actually a 33128.
Air filter [Re: metalfaced] #766245 12/19/13 12:38 AM
redbull Offline
Other options to the K&N. These are from the K&N Website:
http://www.knfilters.com/mobile/kn_cross_ref.aspx?part=E-2871
AC Delco A1050C
Fram CA4369
Mitsubishi MD603384
Purolator A43583
WIX 46238
Page 1 of 3 1 2 3
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.006s) Memory: 0.7490 MB (Peak: 0.9620 MB) Data Comp: Off Server Time: 2026-10-22 07:40:43 UTC
