Heater Core or Heater Hoses? or both? #766484 11/20/06 07:18 AM
trooperbc Offline OP
leaking heater core...or heater hoses...or both?
photos below
1992 isuzu trooper V6 3.2l automatic
after pinpointing 5 weeks ago an intermittent coolant odor to the heater hoses at the firewall, i discovered friday wet carpeting on the passenger side and the driver's side, too.
man that stuff has been sopped up by the felt and insulation backings of the carpet and the sound deading material.
researching here (and there) it sounds to be classic heater core, but . . .after a rediculous amount of time removing parts in order to remove other parts, i've got all the carpeting out and can only find two sources of leaking coolant inside -- both at the inside junctions of where the heater hoses connect on the other side of firewall. --see photo's --
below are some photographs (actually easier to see with the camera than with the on location eye).
questions [color:"red"]
?? when the heater core goes, what exactly goes.[/color] is it the 'radiator' tubes, or is it the plastic tubing that accepts the heater hoses? (which is what actually cracked on my radiator when it went)
??? [color:"red"] where, typically, does the coolant go when the heater core goes. [/color] that is, where does it exit the heater core box. the only coolant leaks inside i can see are at the two places mentioned above and pictured below. (i don't see any coolant at any of the heater box's air tubes.)
the coolant has migrated from those two spots all through and under the carpeting (etc) on the passenger side (as expected), but also over the hump and down into the driver's side carpeting (etc). don't ask me how -- except by wicking or possibly following a harness or ?
naturally, i don't want to replace the heater core box if it really is just the heater hoses, which i thought was the case before i discovered the wet interior. your feedback and photo diagnosis is needed, plus your own experiences with this problem.
engine compartment heater hoses
closeup of heater hoses at firewall in engine compartment û using mirror from below
another mirror closeup
under dash areas of heater box with visible leaks -- both at firewall foam at heater hose 'terminals'.
closeup view of left 'terminal' and sopping wet foam
closeup view of right 'terminal' and it's own little supply of coolant-loving foam sponge
your input is greatly appreciated and needed. i'm especially needing help from those who have replaced their heater cores and can tell me where their coolant actually leaked from, which i hope will lead me in the right direction.
//bc
Re: Heater Core or Heater Hoses? or both? [Re: trooperbc] #766485 11/20/06 03:12 PM
RT1 Offline
Coolant can travel up hill and down as you pointed out by capillary force.
Volkswagen had a notorious design gaff whereby coolant could wick from the coolant expansion tank throughout the entire wiring harness due to a poorly positioned probe. More than a few unfortunates discovered coolant dripping out of their tail lights.
Heat cores are thinly constructed for maximum heat transfer. As such anything on them can go. If you are going to the trouble of taking it apart take it all apart and test the core even if you are sure it's just a hose.
'89 P'up, 2.6 I-Tec, 488,000 miles and done... gone to the great beyond
Re: Heater Core or Heater Hoses? or both? [Re: RT1] #766486 11/22/06 03:32 AM
yeah, thanks. but i'm trying not (hoping not) to take it *all* apart. i really don't want to take the heater box/core out unless absolutely necessary. i'm hoping it might just be the heater hose at the firewall, which is getting that sponge foam soaked, which is making its way to the interior.
i still don't find any evidence of coolant in the air discharge areas of the heater box. i'm thinking that means the heater core isn't leaking. which would mean that it's leaking at the hose or possibly from those 'plastic' inlet/exit points that are attached to the core for the heater hoses.
i haven't seen one of these except installed, so i'm going from that and from the line illustrations in the helm factory workshop manual.
has anybody seen one of these out? can you tell me where it is known to leak?
thanks for your help'
p.s. Happy Thanksgiving !
//bc
1992 sohc trooper 3.2l v6 automatic . . . as is
i love a good intermittent electrical challenge. . .especially when it's someone else's.
Re: Heater Core or Heater Hoses? or both? [Re: trooperbc] #766487 11/22/06 09:50 PM
dvtrooper Offline
If your carpet is wet on the passinger side your heater core is leaking, so do both hoses and a core. Good luck Don
sua dana 44 conversion 5.38 gears, 4.3tbi,700r,dana 300 w/tera low 4:1 gears
Re: Heater Core or Heater Hoses? or both? [Re: dvtrooper] #766488 11/23/06 06:06 PM
OutfitBoss Offline
Yep. mostly when it comes to heater core leaks there ain't no good news. Truth is there isn't a job more frustrating on any kind of vehicle than a heator core replacement. I agree with the owner; try the hoses first. If it helps, great, if not then go from there.
Brian
Brian Rodgers
Internet traffic relayed through DIY solar powered WiFi tower.
www.outfitnm.com
1989 Isuzu Pup gasser
2-86 Isuzu Trooper turbo diesels (1 good 1 bad)
Many gallons of biodiesel since 2005
Re: Heater Core or Heater Hoses? or both? [Re: OutfitBoss] #766489 12/04/06 06:21 AM
F
fastasleep Offline
Yep. mostly when it comes to heater core leaks there ain't no good news. Truth is there isn't a job more frustrating on any kind of vehicle than a heater core replacement. I agree with the owner; try the hoses first. If it helps, great, if not then go from there.
Brian
I beg to differ on that one. I once owned a 77 Ford Econoline and the heater core was in the engine compartment. Switching it out was almost as easy as replacing an air filter. (Considering the rest of the vehicle I'm convinced that the Ford engineers put it there by accident <img src="/forums/images/graemlins/rolleyes.gif" alt="" />)
92 Rodeo
Re: Heater Core or Heater Hoses? or both? [Re: fastasleep] #766490 12/04/06 10:49 PM
Paddler Offline
Unforetunately your issues are exactly identical to mine that I experienced a year ago. I called Merlin at St. Charles and the do not make those cores anymore due to their faulty design. In order to replace it you must replace the entire unit to include the controls. The cost was in the upper $300.00 range and that did not include labor. I still haven't replced mine due to the cost.
1995 Honda Passport;
Some people wait a life time for their ship to sail in, while others simple grab the oars and begin paddling
Yours truely
http://www.zutah.com
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6258 MB (Peak: 0.7247 MB) Data Comp: Off Server Time: 2026-06-20 01:19:55 UTC
